  #1
Old 03-12-2014, 05:00 PM
thomaz thomaz is offline
Senior Member
Default artificial muscles
i have got a question about so called artificial muscles, especially about
Main.HumanModel.BodyModel.Trunk.Buckle.BuckleSuppo rt.Disc1.XPush.ArtificialSupportMuscle
I deactivated the intraabdominal pressure by limiting
Main.HumanModel.BodyModel.Trunk.Buckle.AbdominalPr essureMuscle1 to zero,
but the Artificial muscle still has about 30N. Are these 30N really a mechanical force which would have to be considered in a free body diagram? From where to where is it acting?
Thomaz
  #2
Old 03-13-2014, 10:18 AM
jr@anybodytech.com jr@anybodytech.com is offline
Member
Default
Hi Thomaz,
I think the buckle and the intra-abdominal pressure are two different things. The buckle is an artificial segment on the frontal side of the abdomen that provides insertion points for different abdominal muscles. It is not directly related to the intra-abdominal pressure.
John
  #3
Old 03-13-2014, 10:28 AM
Senior Member
Default
i see, ok.
Does this mean that the mentioned artificial muscle force is acting on this artificial segment?
Thomaz
  #4
Old 03-31-2014, 03:14 PM
mkjung9980's Avatar
Senior Member
Default
Maybe too simple answer is here.
The muscle which you are looking at is:
And its related linear kinematic measures is related to these reference nodes:
Main.HumanModel.BodyModel.Trunk.Buckle.Disc1.Disc. DiscSeg.node0
Main.HumanModel.BodyModel.Trunk.Buckle.Slider1.Seg
So I think you can try to figure out where these nodes are related to.
__________________
Tags
artificial muscles, intra-abdominal pressure
