  #1
Old 02-21-2014, 04:28 AM
less8888 less8888 is offline
Junior Member
Default Muscle Recruitment Criterion
When I set the inverse dynamic criterion as MinMaxStrict, the following error occurred:
1.0) Inverse dynamic analysis...
ERROR(OBJ.MCH.MUS4) : D:/a..s/AMMR/A..n/E..s/G..y/GaitLowerExtremity.main.any : InverseDynamicStudy.InverseDynamics : Muscle recruitment solver : maximum number of setbacks occured
I 've no idea about this, so how to solve this prooblem?
Many thanks.
Thomas
  #2
Old 02-21-2014, 10:01 AM
danielnolte danielnolte is offline
Senior Member
Default
Hi Thomas,
Which model are you running? Which AMMR/AMS versions do you have?
Have you tried other solvers, e.g. the MinMaxAux? For debugging, you could also increase the order for a polynomial criterion to see how it behaves and if there are also problems showing up.
Daniel
  #3
Old 02-22-2014, 06:07 AM
Junior Member
Default
Hi Daniel,
Thanks for your reply!
My model is GaitLowerExtremity and I changed the C3D data. And the 5.3 version is used.I have tried other solvers and got results.
Thomas
Tags
muscle recruitment
