Old 01-12-2018, 08:25 PM
PhoebeHsu PhoebeHsu is offline
Default How to average gait cycles?
Dear AnyBody:
I have a general question regarding using AnyBody to perform musculoskeletal modeling. Typically, the user choose the beginning and the end of a gait cycle, within which all variables (moments/forces) will be calculated. However, as shown in the attachment, there are always substantial cycle-to-cycle variances. Is it possible to let AnyBody run for a few cycles, and then output the average of kinematics/kinetics from those cycles?
thanks,
-Phoebe
Old 01-15-2018, 09:37 AM
Dear Phoebe,
Not out of the box. The question is indeed tricky, because as you say yourself there is some variability even within cycles. You would need to extract start/end time, which may vary as well, and normalize all cycles to, say, 0-50-100 percent phase. This information is not intrinsic and needs to be computed. It is probably easier to do externally through Python/Matlab scripts.
It is also possible to treat these different cycles as new trials and just split all of them (using tStart/tEnd). Then when postprocessing the output - average by the subject/c3d file name.
Old 01-22-2018, 08:58 PM
thanks Pavel. I shall investigate all the available approaches and report what I find to the community.
-Phoebe
Old 01-25-2018, 09:31 PM
Quote:
Originally Posted by pgalibarov View Post
Dear Phoebe,
Hi Pavel,
Can Anybody determine the start and end of each gait cycles timing and store it in the C3D file? Or those are defined by the user and AnyBody only does kinematic/kinetic calculation based on the selected frame(s)?
Thanks,
-Phoebe
Old 01-30-2018, 10:50 AM
Hi Phoebe,
No, those should be defined by the user at this point.
  #6
Old 03-07-2018, 10:17 PM
Hi Phoebe,
Hi Pavel,
Can AnyBody read ascii files instead of c3d files, which include trajectory information of the physical markers and FP reaction forces?
Thanks,
-Phoebe
  #7
Old 03-08-2018, 09:54 AM
Hi Phoebe,
Yes, of course. But you would need to implement your own soft marker drivers.
  #8
Old 03-08-2018, 05:10 PM
Hi Phoebe,
Hi Pavel,
Thank you for your reply!
As shown in the picture, I calculated the mean and standard deviation of the trajectories of each marker (the figure shows the Z- motion of the LKNE) during multiple cycles. Time was normalized to be between 0 to 100. GRF was processed in a similar way.
I haven't found a way to rewrite the data (ascii) to c3d so it can be directly read by AnyBody. If AnyBody can read kinematic information of the markers and the kinetic information of the FPs it will be great! Your thoughts are suggestions are greatly appreciated.
-Phoebe
  #9
Old 03-08-2018, 05:20 PM
Hi Phoebe,
Not sure if I understand what you meant by "soft marker drivers".
Usually I will pick one cycle of this c3d file to run AnyBody. Now, I would like to use the average of multiple cycles of the same c3d files to drive AnyBody. I can get the kinematic info (i.e., markers' trajectories) and kinetic info (i.e., GRFs), both of which are in acsii format. If I didn't specify soft marker drivers when using normal c3d input, is it still necessary to specify them when using an acsii file derived from that same c3d file?
Thanks!
-Phoebe
  #10
Old 03-15-2018, 09:19 AM
Hi Phoebe,
It is not a good idea to use average data as input to the analysis in AnyBody, for several reasons:
• For a segment with two markers on, in one trial their distance will be constant, after averaging of data this is no longer the case.
• After doing averaging on marker data the motion will have changed and there is no guarantee it will match the average of the GRF so you may see high residuals.
