Old 01-12-2018, 09:25 PM
PhoebeHsu PhoebeHsu is offline
Member
Default How to average gait cycles?
Dear AnyBody:
I have a general question regarding using AnyBody to perform musculoskeletal modeling. Typically, the user choose the beginning and the end of a gait cycle, within which all variables (moments/forces) will be calculated. However, as shown in the attachment, there are always substantial cycle-to-cycle variances. Is it possible to let AnyBody run for a few cycles, and then output the average of kinematics/kinetics from those cycles?
thanks,
-Phoebe
Old 01-15-2018, 10:37 AM
Dear Phoebe,
Not out of the box. The question is indeed tricky, because as you say yourself there is some variability even within cycles. You would need to extract start/end time, which may vary as well, and normalize all cycles to, say, 0-50-100 percent phase. This information is not intrinsic and needs to be computed. It is probably easier to do externally through Python/Matlab scripts.
It is also possible to treat these different cycles as new trials and just split all of them (using tStart/tEnd). Then when postprocessing the output - average by the subject/c3d file name.
