Old 05-11-2012, 09:04 AM
Shingo Shingo is offline
Unhappy Use c3d data
Hello, I`m Shingo.I belong Japanese college and new anybody user.
I post for first time.
Actually, I think when I use "c3d file",make animation.
But, when run kinematics,there are many times error messages.
I confuse.Help me!!!!
I attach data ,now.Please, check this data.
This data is that I think move one point.So,I use one segment and function.
Old 05-11-2012, 12:55 PM
mkjung9980's Avatar
mkjung9980 mkjung9980 is offline
Hi,
Welcome to AnyBody world!
1) First, I would recommend you to use GaitFullBody example.
You had better to practice this model first.
2) When I see your C3D file, the marker names are different from Plug-in-gait marker set.
So you are not an experienced AnyBody user, I would recommend you to use Plug-in-gait marker set.
3) In your C3D file there is no force plate data.
It means that you may not be able to do inverse dynamics well.
If you have more questions, please write here as a reply.
Moonki
Moon Ki Jung, Ph.D, Application Engineer, AnyBody Technology A/S.
※ AnyScript™ Reference Manual is the bible.
※ AnyScript™ wiki page is the best supplementary information(http://wiki.anyscript.org).
※ When you would upload your models, please write information about your AMS and AMMR versions.
※ If you want to get more intensive support, please update your information(profile, organization and signature).
Old 05-14-2012, 04:24 AM
Thank you for message.
Your answer was helpful.
But, I don`t know Plug-in-gait.
So,please tell me Plug-in-gait.
Old 05-14-2012, 08:58 PM
aalmunajjed aalmunajjed is offline
Dear Sakurai Shingo,
here is a paper that describes marker protocols and also Plug in Gait:
http://www.sciencedirect.com/science...66636208001586
I hope that helps.
Best regards, Amir
Amir Al-Munajjed, AnyBody Support
Please provide AMMR and AMS version numbers in case you send a debug model. The folder structure should follow the standard in the AMMR. This makes it a lot easier for us to answer your questions faster.
Consider to subscribe to a forum, click the 'ForumTools' link above the list of threads then select 'Subscribe to Forum'.
Old 05-16-2012, 03:58 AM
Thank you for message , aalmunajjed.
To mkjung9980 , I will purchase the OptiTrack 's motion capture system and use ARENA to analyze. So , I can't use VICON 's motion capture system. I have question that Anybody reads ARENA 's c3d data. Please tell me it.
  #6
Old 05-16-2012, 09:33 AM
You can use C3D files that were captured with OptiTrack and analyzed with Arena. However, you have to adapt the model.
Please have a look at the tutorials:
http://www.anybodytech.com/fileadmin...e/lesson5.html
and try to understand the function of the GaitLowerExtremity, or the GaitFullBody model.
Make a copy of the GaitLowerExtremity, adapt the marker names in the model to the Marker names from your C3D file, out-comment the force plates, ....
Please be aware, that without ForcePlate data, running the inverse dynamics will NOT be possible!
Best regards, Amir
  #7
Old 05-18-2012, 04:36 AM
Thank you , aalmunajjed.
I do reference of your opinion and try to do AnyBody.
This c3d data is Optitrack's sample data.To use it , I practice to use AnyBody , now.
After I get motion capture system , to use force sensor I measure external force. To utilize it , I will run inverse dynamics.
Tags
c3d
