  #31
Old 03-18-2010, 08:29 AM
sadper sadper is offline
Junior Member
Default
Is manual that tells me the markers label or the location of the markers?
Regards
TS
  #32
Old 03-18-2010, 09:12 AM
sdendorfer's Avatar
sdendorfer sdendorfer is offline
AnyBody Support
Default
no, there is no such manual. This is because there is no fixed marker set. You can define any marker at any location to fit your individual experimental setup. The given Gait models in the repository are only examples of such experiments. The first step is to create/change the marker locations in the AnyBody model to fit to your experiments. If your experimental marker kit is fixed this is a once-and-for-all-task.
Sebastian
__________________
__________________
Sebastian Dendorfer, AnyBody Support
  #33
Old 03-28-2010, 01:29 PM
Junior Member
Default
I am modify the GaitVaughan markers location but i get the following error when i run the inverseDynamic.
I input a markers file with a longer timing (0.2-3.5). The markers is all around the human.
Infact, this is a motion of bending the upper body with the leg not moving (the leg also have markers on it).
Failed to resolve kinematic constraints (final kin. error = 1.936164E-001)
Constraint no. 0 above error tolerance 0.000001, error = 0.000008. - constr. #0 in 'Main.HumanModel.BodyModel.Trunk.JointsLumbar.C0C1 Jnt.Constraints'
Constraint no. 191 above error tolerance 0.000001, error = 0.027762. - constr. #2 in 'Main.Model.ModelEnvironmentConnection.JointsAndDr ivers.HeelYLDrv'
ERROR(OBJ.MCH.KIN3) : D:\AnyBodyModelRepositoryV1.0\Application\Examples \GaitVaughan\GaitVaughan.main.any(134) : 'Study' : Kinematic analysis failed in time step 0
Regards
TS
  #34
Old 03-29-2010, 10:01 AM
sdendorfer's Avatar
AnyBody Support
Default
it could be related to the initial positions. Please make sure that the model is placed close to the marker positions when you set initial conditions.
Sebastian
__________________
__________________
Tags
c3d
