  #1
Old 01-10-2013, 08:13 AM
shinyoonho shinyoonho is offline
Member
Default c3d file ERR
hi~
i'm first step in anybody student...
I think that my c3d file have a problem
attached ERR message(Run GaitLowerExtremity), c3dfile,
and I want About what kind of role the display part(Red line) of the picture file
GaitLowerExtremity
Model parameter optimization option =1
Inverse dynamic= 0
F7
run motionandparameteropimization Run <<<<<<<<< ERR
please help me
  #2
Old 01-11-2013, 08:54 AM
mkjung9980's Avatar
Senior Member
Default
I'm testing your C3D file in the latest AMS V5.3 and AMMR V1.5.1.
In this version there is no problem in loading your C3D file.
So I would strongly recommend you to update your AnyBody software as latest version.
By the way, we could find some problems about the force plate data in your C3D file.
Which manufacturer of force plate system did you use for this C3D file?
__________________
  #3
Old 01-11-2013, 10:56 AM
mkjung9980's Avatar
Senior Member
Default
Attached please find a test model and the snapshot of that model.
This model is created based on AMS V5.3 and AMMR V1.5.1.
In terms of 'Kinematics', this model will work.
But the problem is that the information about force plate in your C3D file is wrong.
As you can see the attached snapshot file, the sequence of corner points seems wrong.
You can find more detail information about the specification of C3D file here:
http://www.c3d.org/HTML/default.htm?...tformgroup.htm
I would recommend you to contact to your force plate manufacturer about how they create its C3D file.
__________________
  #4
Old 01-15-2013, 08:07 AM
Member
Default
Hi~
Thanks to you
I can next step thanks for your adjustment
//Another problem occurred
//(my test file frame have 200 frame but AMS output is 10~20 frame ,
//I performed 2step gait but AMS data have first one step(half))
//solved this problem
In addition I would like to know the difference between the sent filefolder(GaitLowerExtremity_KKU) and original filefolder(GaitLowerExtremity)
and you pointed out, forceplate is reverse mean? or other problem?
  #5
Old 01-15-2013, 04:29 PM
mkjung9980's Avatar
Senior Member
Default
1) The main differences are 'ModelSetup.any' and 'ExtraDrivers.any' files.
Because you didn't use enough markers in the upper body, you should modify 'ModelSetup.any' file. You can check it in the first capture file.
And also because there is not enough information in your C3D about how to drive the upper body, so in the 'ExtraDrivers.any' file you should use some drivers for Pelvis-Thorax rotations.
2) If you can see the second capture file, you can see that the local coordinate system of your force plate is flipped.
If you can see the following information about C3D file for force plate, then the local Z axis of the force plate coordinate system should go into the ground.
http://www.c3d.org/HTML/default.htm?turl=corners.htm
But in your C3D file, the direction of Z axis is wrong.
You should ask to your lab technical support about how you can generate the correct C3D file, maybe Motion Analysis Corp..
If you want to use AnyBody with your laboratory environment, you should correct this problem as soon as possible.
__________________
  #6
Old 01-16-2013, 03:56 AM
Member
Default
HI
attached to another file
z axis was inverted(using cortex program)
I'm following the end of the experiment
Are Changing the file from the cortex program?
Did I understand your description correctly?
I am always grateful for your answers
  #7
Old 01-16-2013, 08:23 AM
Member
Default
change c3d file TT >> TT4
change TT4 FP axis changed as basic c3d file
  #8
Old 01-16-2013, 08:56 AM
mkjung9980's Avatar
Senior Member
Default
It seems that you could change the coordinate system of force plate correctly.
But when I look the COP and force, then still it seems wrong.
COP should be under the foot.
You can download this software MOKKA and open your C3D file.
http://b-tk.googlecode.com/svn/web/mokka/index.html
Please contact to your force plate technical support or motion capture software provider to solve this problem.
__________________
  #9
Old 04-26-2013, 09:38 PM
eprasilova eprasilova is offline
Junior Member
Smile
here is my c3d file, i have problems load it in GaitFullBody. Thank you for your answer and for your another help.
Eva
  #10
Old 04-29-2013, 08:37 AM
mkjung9980's Avatar
Senior Member
Default
When I looked your C3D file very quickly, there are two problems.
1) The RTHI marker in your C3D file is almost dropped-out.
This may the reason of the kinematic error.
2) Both left and right feet are on the same single force plate.
Of course this second issue is not related to the kinematics.
But if you want to perform the inverse dynamics, then I would recommend you to use one more force plate.
If you still can't figure out how to solve your problem, then please upload your full AnyBody model here as a zip compressed file.
__________________
Tags
c3d
