  #11
Old 01-29-2014, 11:31 PM
sts07009 sts07009 is offline
Junior Member
Default
Hello Daniel,
I have attached a new file.
Thanks
  #12
Old 01-30-2014, 01:13 PM
danielnolte danielnolte is offline
Senior Member
Default
Hi Stephany,
There have been some problem with the forum webpage which caused these problems downloading your model. These have been fixed now. Unfortunately the second file you uploaded was still incomplete due to this issue. Could you upload your model once more so that I can finally have a look at it?
Daniel
  #13
Old 01-30-2014, 03:38 PM
Junior Member
Default
Daniel, Thanks for your help.
As an AnyBodyScript formatting question.
The first line of the main file is #include "../libdef.any" which eventually brings me to BodyModel.constants.any. In this file, it states #inndef BM_CONSTANTS_DECLARED and then several #define statements pertaining to the BM definition.
My question is, if I add in code in the main file for the BodyModel such as #define BM_Leg_Left... AFTER the #include libdef.any, does this mean my added statement with the constants I wish the bodymodel to have is not used, or will the settings be overwritten when the code reads my #define statements afterward?
Thanks!
  #14
Old 02-04-2014, 10:29 AM
Senior Member
Default
Hello Stephany,
I had a look at your model and have some comments.
  • You started your model from the MoCap model from repository 1.6. This model is not using the BM statements to configure the body model (this will be changed in the next versions). Therefore, if you want to switch off legs and the left arm, you have to modify the file BodyPartsSetup.any. If you switch off some of the body parts, you also don't need to define drivers for them.
  • Are you sure about the mapping of nodes to landmarks? I have the impression that you mixed them up since the shoulder marker moves quite a lot.
  • You only have three markers which might be enough to describe the position of shoulder, elbow and wrist. But you have to drive the rotations of the separately since they are not determined in this case.
To your question: after the #include "../libdef.any" is the right place to put the #define BM_* statements, but unfortunately, these are not used in this model as I said before.
Daniel
Tags
c3d, coordinates, mocap, recumbent
