  #11
Old 01-30-2015, 12:30 AM
laul.sins laul.sins is offline
Senior Member
Default
Wooops, sent my answer too early !
Would anybody help or guide me to find the node on thorax I'm looking for ? Please, refer to my previous post (#6). Thank you !
Lauranne
  #12
Old 01-30-2015, 03:40 PM
mkjung9980's Avatar
Senior Member
Default
Dear Lauranne,
Usually most of the AnyRefNodes in the AnyBody segments are related to either origin or insertion points of the muscles which are attached on that bone.
So what I would do is:
1) Turn on all the muscles in the trunk
2) Find the muscles which has your point of interest as either origin or insertion point
3) Move your mouse on the muscle and find that muscle in the model tree.
4) Then you can find the references of those points in the model tree.
I thinks this process will work.
__________________
  #13
Old 02-05-2015, 10:47 PM
Senior Member
Default
Thank you Moonki for your advice !
I followed your steps and, you're right, it's rather easy to find the corresponding nodes.
My next question is the following: I'd like to create a Folder to store the references to the nodes where the Vicon markers are attached. For example, for only two of these markers, I wrote the following code:
Code:
AnyFolder &BodyModel=Main.HumanModel.BodyModel;
BodyModel={
  AnyFolder MarkersOnBones={
    AnyRefNode &THORAX1 = Main.HumanModel.BodyModel.Trunk.SegmentsThorax.ThoraxSeg.ij;
    AnyRefNode &THORAX2 = Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.PelvisSeg.RANode ;
I'd like to add a "AnyDrawNode" (at each node) or "AnyDrawNodes" (for all nodes) but I can't figure out how to do it :/ I tried the following code but (as I expected !) didn't worked; the error I got being "ERROR(OBJ4) : D:/D..x/1..l/A..n/L..n/M..l/MarkersOnBones.any(32) : drw : Wrong owner class for AnyDrawNodes. Accepted owner(s): Any3DObject or derived"
Code:
BodyModel={
    THORAX1  = {AnyDrawNode drw= RGB = {0,0,1}; ScaleXYZ = {1,1,1}*..ScaleNode ;
    AnyDrawNodes DrwNodes= {RGB = {0,0,1}; ScaleXYZ = {1,1,1}*.005;};
Could you help me and explain to me what is the correct code ?
Thank you !
Lauranne
  #14
Old 02-10-2015, 01:41 PM
Senior Member
Default
Lauranne,
this will show all nodes in the humerus:
Main.HumanModel.BodyModel.Right.ShoulderArm.Seg.Hu merus = {
AnyDrawNodes dddddddd = {};
So, maybe this would work for you:
AnyFolder TEst = {
AnyRefNode &Node1 = ...;
AnyRefNode &Node2 = ...;
but I'm not sure if it will work with the folder instead of a segment.
__________________
Best regards, Amir
__________________
  #15
Old 02-10-2015, 06:52 PM
Senior Member
Default
ok, thank you for your tips.
Finally, the answer is "no": adding AnyDrawNodes in a folder (i.e. not a segment folder) does not work.
So, here is the new question: how to easily draw nodes, i mean without having to go to the file were nodes are created? For example: the node "aa" located on the scapula segment/bone is created in the file "Seg.any". My idea was to create a pointer and to add the node to this pointer:
Code:
THORAX1  = {AnyDrawNode drw= RGB = {0,0,1}; ScaleXYZ = {1,1,1}*.004;};
However, since "THORAX1" is seen as a folder, I cannot use the AnyDrawNode (or AnyDrawNodes) function...
Any idea(s)?
Lauranne
  #16
Old 03-02-2015, 06:38 PM
Senior Member
Default
I come back on the message of Moonki:
In fact it appeared that the T8 node is not linked to any muscle (please, see attached picture, I'm looking for the green circled node). I tried by a trial and error process but, really, I am absolutely unable to found the reference of this node. Would you have any other advice or idea to get its reference?
Thank you !
Lauranne
  #17
Old 03-05-2015, 10:14 AM
Senior Member
Default
Just searched for it a while myself without success. Before spending more time, I would make a new node in a similar position.
__________________
Best regards, Amir
__________________
  #18
Old 03-05-2015, 02:58 PM
Senior Member
Default
"good" news to see that there is not any easy solution !
In fact, I did what you're suggesting; but I was interested in using the existing nodes to get the scale function already defined on them.
Lauranne.
Tags
anyinputc3d, c3d, c3d2any, rancho, wheelchair
