  #1
Old 03-06-2015, 06:02 PM
jcho44 jcho44 is offline
Junior Member
Default Converting Motion Monitor to AnyBody
Greetings,
I am a Senior at the University of Connecticut working on my senior design project. The project is the 3D modeling of a leg that will be used in a total knee replacement diagnosis. Right now My team and i are having a problem converting our files in our mocap program called The Motion Monitor, using a C3D file. We keep getting an error message stating that the data acquisition boards do not have the same voltage. We have talked to the company and they do not know what the problem is either. This is the last step needed before we import our data into AnyBody. has anyone come across this problem before using other systems or has any other solutions as to how we could import our data without a C3D file?
Thank you very much for your time,
John
  #2
Old 03-10-2015, 09:39 AM
Senior Member
Default
Dear John,
I've never heard of such a problem, I also never heard of the motion capture system before.
There are models that use marker data based on text files, but having a C3D makes it a lot easier and smoother.
__________________
Best regards, Amir
__________________
  #3
Old 03-13-2015, 09:46 PM
Junior Member
Default Converting C3D2Anyscript
I have just received the ability to create C3D files with the motion capture data I have collected. I have also installed the c3d2anyscript converter. However I have Anybody version 6.o and the homepage states that this converter is meant for versions 2.0 and 3.0. I am also new to this software and I am unable to understand how to exactly open my c3d file in anybody and create my model. If anyone could suggest a process to do this or a manual to read that will help with this procedure that would be great.
Best Regards,
John
  #4
Old 03-16-2015, 08:50 AM
Senior Member
Default
There is no need to use this c3d2anyscript tool, I think that was necessary 10 years ago, but know everything is implemented into AnyBody itself:
just use the MoCapModel from the repository and follow this tutorial:
http://www.anybodytech.com/fileadmin...e/lesson5.html
and look at this Wiki:
http://wiki.anyscript.org/index.php/...p_driven_Model
__________________
Best regards, Amir
__________________
  #5
Old 03-24-2015, 06:43 PM
Junior Member
Default Mocap, c3d
aalmunajjed,
Thank you for you help. I have been reading through the wiki page and figured out that the system I am using, uses a type 5 force platform which is not listed in the tutorials. We are also only using one platform with both legs on it. However, we are only simulating one leg before exporting the file. The team an I are also implementing EMG data. Could you refer me to a model that would better suit our model or a more extensive tutorial that will also include how to directly import the c3d file we are using?
Thank you,
John
  #6
Old 03-25-2015, 09:14 AM
Senior Member
Default
John,
as I said in my last post, use the MoCapModel from the repository and follow this tutorial:
outcomment the forceplates for the beginning, and try to focus on the kinematics = MotionAndParameterOPtimization
afterwards you should upload your model to the debug section and we'll have a look at the forceplates.
afterwards, there is a post from Kirsten, she had also two legs one forceplate:
http://forum.anyscript.org/showthread.php?t=3812
__________________
Best regards, Amir
__________________
Tags
c3d, c3d2any, motion capture data error
