  #1
Old 05-08-2018, 11:24 AM
uricoco11 uricoco11 is offline
Junior Member
Default Making joint on solid works model
Hello.
I made rigid model in solid works and transfered to anybody.
I wanted to make cylinderical joint between ground and rigid body.
When I started kinematic analysis, the error was occured(above tolerance)
How can I fix it?
Please check the below file.
Thank you.
