  #1
Old 06-14-2018, 03:05 PM
uricoco11 uricoco11 is offline
Junior Member
Default Applying the C3D file
I load human model and made marker in head.
I applyed c3d file and wrote the codes like below.
AnyKinDriverMarker C3Dmotion =
AnyRefFrame &Marker = Main.HumanModel.BodyModel.Trunk.SegmentsThorax.Sku llSeg.Head_track_Node;
AnyParamFun &Trajectory = Main.Model.Environment.C3D.Points.ProcessedData.RF HD.PosInterpol;
I want the Head_track_Node to follow posion of C3D files
However Head_track_Node doesn't follow and move.
please check my file.
thank you.
  #2
Old 06-20-2018, 03:40 PM
mkjung9980's Avatar
Senior Member
Default
1) First of all, it seems that your C3D file is not normal, which means that it does not seem to contain proper marker trajectories. Please check it first.
2) If you want to drive the human model, it will be nice to start with our MoCapModel instead of the standing model.
Which version of AMS and AMMR are you using at the moment?
__________________
  #3
Old 06-21-2018, 03:26 PM
Junior Member
Default MoCapModel
As you said, I imported MoCapModel and modified.
but I have a another poblem.
I want to make other markers or change the marker position.
For example,
In 'Markers_TLEMv2.any I changed the positions of RTIB and LTIB
and ran the kinematic analysis.
since the markers positons were changed, result should be changed in my think
but nothing was changed.
how can I fix it?
thank you.
  #4
Old 06-25-2018, 10:15 AM
mkjung9980's Avatar
Senior Member
Default
1) As I explained in the previous thread, you should really check whether there is any problem in your C3D files. As far as I saw in your previous file, there was no proper marker information in your C3D file.
2) As I asked you before, which version of AMS and AMMR are you using?
3) If you are really sure that you are using our MoCapModel, try to upload your model in the debug section. In this case, please specify your AMS and AMMR versions.
__________________
  #5
Old 06-25-2018, 10:35 AM
Junior Member
Default
I used AnyBody version : 7. 1. 1. 6029
AMMR 2.1.0
and I used MoCapModel of MoCap_FullBody.main.any in example not basic MoCapModel.
and I didn't use my C3D file.
I want to see the motion change when marker's position is changed.
In 'Markers_TLEMv2.any, when I changed the positions of RTIB and LTIB
Red markers were changed except blue markers.
So my question is that can't change the motion by changing position of marker in gait example of mocapmodel?
thanks
  #6
Old 07-09-2018, 01:55 PM
mkjung9980's Avatar
Senior Member
Default
Usually in the MoCapModel, the blue markers represent the trajectories of the markers in your C3D files, whereas the red markers represent the locations of the markers in the AnyBody human model.
As far as the blue markers are not changed, you should not expect the change of the human model even if you change the red marker definitions. That is not the correct use of the model.
Of course you can adjust the location of the red markers a little bit. But in principle, that will not change the human motion dramatically.
__________________
  #7
Old 07-10-2018, 09:22 AM
Junior Member
Default
Thanks for your help
Can't I change the blue markers in anybody?
  #8
Old 07-10-2018, 03:03 PM
mkjung9980's Avatar
Senior Member
Default
You can't change the blue markers in AnyBody because those information comes from the C3D file. And they are one of the input for your simulation. I don't see any reason why you should modify those information.
/MJ
__________________
