Old 05-08-2014, 06:29 PM
thomaz thomaz is offline
Default scaling with rotation
Dear all,
for some modifications and want to rotate the skull by modifiying the scaling law like this in ScalingUnivorm.any:
Code:
    AnyFolder HeadOriginal = {
      AnyVar GeomScale = (..AnthroSegmentLengths.HeadHeight / ..StandardParameters.Head.Height);
      AnyFunTransform3DLin ScaleFunction = {
        ScaleMat ={{.GeomScale,0,0},{0,.GeomScale,0},{0,0,.GeomScale}};
        Offset = {0,0,0};
    AnyFolder Head = {
        PreTransforms = {&..HeadOriginal.ScaleFunction};
        ScaleMat = RotMat(-45 *pi/180, y) ;
        Offset = {0,0,0};
As the scaling function is called within the SkullSeg for the definition of all nodes and the graphics, graphics and nodes should behave like in a rigid body motion.
But although all nodes and the graphics should rotate in the same way, they do not: The nodes are rotated around another axis than the graphics. Please have a look at the attached figures. What could be the reason?
Thanks for any hint,
Thomaz
Old 05-08-2014, 06:59 PM
Thomas,
There is a problem in the definition of some nodes:
Code:
   AnyRefNode SternocleidomastoidNode = {sRel = .Scale({-0.034+0.018+0.01,-0.025+0.005,0.074})*.Mirror;};
Mirroring has to happen before scaling. This sequence causes some nodes not to rotate visually. The fix would be (will need to scroll):
Code:
   AnyRefNode SternocleidomastoidNode = {sRel = .Scale({-0.034+0.018+0.01,-0.025+0.005,0.074}*.Mirror);};
Was the problem in the Sternocleidomastoid and a couple of more muscles? Or is it something that you're implementing yourself?
Regards,
Old 05-09-2014, 10:32 AM
Hi Pavel,
thanks for the speedy reply. In my case there is no Mirror included. I use AB5.3, AMMRV1.5, StandingModel, SkullSeg in SegmentsThoraxWithoutNeck.any, e. g.
Code:
    AnyRefNode LumpedHyoidT1C0NodeR = {sRel = .Scale({0.006+0.018,-0.006+0.005,0.018});AnyDrawNode drw ={};};
    AnyRefNode LumpedHyoidT1C0NodeL = {sRel = {.LumpedHyoidT1C0NodeR.sRel[0],.LumpedHyoidT1C0NodeR.sRel[1],.LumpedHyoidT1C0NodeR.sRel[2]*-1};AnyDrawNode drw ={};};
The second node has just the z coordinate negative. This should be all right, shouldn't it?
I assume that something is wrong with my modified scaling law. When i transform (rotate) around x, the nodes rotate around z (rotation on midsagittal plane). The skull anysurf however rotates around x (lateral bending to the right or left).
Therefore there are two points which i do not understand:
1.) Why is the anysurf scaled differently than the nodes although they are scaled by the same scaling function,
2.) why do the nodes sometimes not move as a rigid body (there distance before and after scaling is different). They are only like a rigid body when rotating around x.
Could you please exchange the original scaling law with my modified one to see what i mean?
Thanks and kind regards,
Thomaz
Old 05-09-2014, 03:47 PM
Thomas,
I think this is the same problem. Try this:
Code:
 AnyRefNode LumpedHyoidT1C0NodeL = {sRel = .Scale({0.006+0.018,-0.006+0.005,-1*0.018});AnyDrawNode drw ={};};
It can also be reorganized a little different:
Code:
AnyVec3 LumpedHyoidT1C0NoderVec = {0.006+0.018,-0.006+0.005,0.018};
AnyRefNode LumpedHyoidT1C0NodeR = {sRel = .Scale(.LumpedHyoidT1C0NoderVec);AnyDrawNode drw ={};};
 AnyRefNode LumpedHyoidT1C0NodeL = {sRel = .Scale(.LumpedHyoidT1C0NoderVec*{{1,0,0},{0,1,0},{0,0,-1}});AnyDrawNode drw ={};};
But the problem is the same that the mirroring happen after you scaled.
I actually found the problem by using your scaling law. I think it may be the same for a few more points - it's not that frequently used.
Regards,
Old 05-09-2014, 04:34 PM
aaah, yes, of course. Thanks!
But this only explains why the nodes do not behave like a rigid body.
For rotation around x or z the DrwSurf1 from SkullSeg still performs lateral bending while the nodes do a flexion-extension and vice versa. Only for a rotation around y, DrwSurf1 and nodes behave in the same way.
Any ideas on that?
  #6
Old 05-09-2014, 05:08 PM
Thomas,
That's also an interesting problem. There was a special rotation that was accounted for rotating the STL of the skull, which had 90 degrees of rotations. ARel = {{0,0,-1}, {0,1,0},{1,0,0}}. If we comment this one out - it behaves like it should, but we also need to change the stl of the skull. I have done and it works perfect. What i did i applied this rotation matrix to the STL and this way i could eliminate rotation from the code.
Code:
    AnyRefNode drworientation = {
      sRel = .Scale({0.0, 0.0, 0.0});
      //ARel = {{0, 0, -1}, {0, 1, 0}, {1, 0, 0}};
      AnyDrawSurf DrwSurf1 = {
        FileName = "./BonesSpine/SkullUpdated";
        RGB = ....ColorRef.Segments;
        ScaleXYZ = {1, 1, 1};
        AnyFunTransform3D &Scale =..Scale;
        Opacity = Main.DrawSettings.BonesOpacity.Skull;
But this was only a visual problem.
Regards,
  #7
Old 05-09-2014, 05:15 PM
Hi Pavel,
i understand now. Thanks.
How did you transform the STL? Can this be done with a command in the STL code or in the anysurf file?
Thanks for your help and kind regards,
Thomaz
  #8
Old 05-09-2014, 05:19 PM
I rotated in Meshlab an exported STL, but this can also be done in AnyBody.
Code:
// not checked code
AnyFixedRefFrame fr  = {
 AnyDrawSurf SkullNew = {
   FileName="<ANYBODY_PATH_BODY>\Trunk\BonesSpine\Skull";
   AnyFunTransform3DLin tr = {
      ScaleMat={{0,0,-1},{0,1,0},{1,0,0}};
      Offset ={0,0,0};
And then use a class-operation and export in global - i think that will do the trick. I just used whatever came quickest to my mind
P.
  #9
Old 05-09-2014, 05:21 PM
looks good, nice.
Thanks again and nice weekend,
Thomaz
Tags
rigid body, rotation, scaling, transformation
