  #1
Old 09-06-2018, 04:47 PM
John John is offline
Junior Member
Default Integrate an amputation into a MoCap Model with MechObjectExclude
I am working on a MoCap Model for the lower extremity and try to integrate a unilateral transfemoral amputation into it. The idea is to do it with the object "MechObjectExclude" in the LegExchange.any file. So if the amputation is activated in the LabSpecificData.any file and the inverse dynamic study is started, on the left side a lot of muscles should be excluded together with the segments "Shank" and "Thigh" and also the Joint "Knee". In the LegExchange.any file, after the exclude methods, are also new muscles, segments and joints defined which represent the amputated case.
The problem now is, that if I am loading the model, I get the warning that the Leg Calibration Studies contain too few kinematic constraints. So if I am running the InverseDynamics it starts but of course fails because the model is kinematically indeterminate. But I mentioned in the model view, that the segments, joints and muscles that should be excluded when the inverse dynamic study is started are still present and not excluded. So know I am not sure, whether there is a mistake in the LegExchange.any file I created with the exclusion of these objects and if this could get fixed anyhow or if it generally does not work that way I am trying to integrate an amputation to the model.
Many thanks in advance,
John
File Type: any LowerExtremity.main.any (459 Bytes, 1 views)
  #2
Old 09-11-2018, 09:21 AM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
Hi John,
I have looked at bit at your files and i think i have found the reason for the problem.
You exclude segments, joint and muscles from the inverse dynamic study, so only this study is affected by this.
Then you open up the folder " Main.HumanModel.BodyModel.Left.Leg" and start adding muscles, segs etc.
So the added items are going into the normal body model and all studies using this body model will have these new items which has been defined.
This leeds to problems in the calibration study.
The solution depends on what you want to do:
1: if you would like to run the calibration on a non-amputee model then, you have to add the these new body parts to a folder which is not part of the human model and thus included by all other studies.
2: If you like to run all studies on an amputee model you need to do the exclusion in all studies. Instead of doing this for each study one by one you can use the object AnyMechObjectExcluder for this it .
Hope it helps.
but you insert the new body parts into t
__________________
  #3
Old 09-11-2018, 03:56 PM
Junior Member
Default
Hey Søren,
thank you for your ideas!
I tried to do it with the second way and put the exclusion in all studies. I don't know if i really got it right with what you mean, that I don't have to do it for each study one by one. The only way I managed to do it, is by doing it with the MechObjectExclude object for each LegCalibrationStudy. You can see it in the modified LabSpecificData.any file I attach to this post.
But when I load the model now, it still gives me the same warnings, that the LegCalibrationStudies contain too few kinematic constraints. Despite the warnings, I started the InverseDynamics within the folder "RunAnalysis" and this runs further now than before, but also fails. The error now is: "Unknown error: No Class Information".
My whole model is too large to attach it to my post, but I made a Dropbox-folder and with the following link you have access to it, if you maybe would like to run the model by yourself.
https://www.dropbox.com/sh/n51vjcyti...qTXioe-Na?dl=0
Thanks again and best regards
John
  #4
Old 09-11-2018, 04:28 PM
toerholm's Avatar
AnyBody Support
Default
Hi John,
I will try to explain in some more detail.
Concerning the calibration there are two ways as i listed.
1: you do the calibration as if it was the non-amputee model
2: you do the calibration on the amputee model
This is not a modeling question but more fundamental, i think that option 1 is more correct since this will calibrate the model as it was intact. Option 2 will adapt muscle to the changes done by the amputation... Which situation is correct i am not sure it depends on the surgical procedure.
To check which object you have in the studies you can in the ModelTree click on the study in question e.g. the calibration study then you can in the object description get a complete list of segments, joint and drivers... please review this list carefully to see if you have excluded things correctly and if you have added things correctly.
I looked again on the legExchange.any file it seems you are removing both thigh and shank but not the foot and talus? this i did not understand.
__________________
  #5
Old 09-21-2018, 03:59 PM
Junior Member
Default
Hi Søren,
after your last response I managed to do some changes to my model and now everything should be excluded and added correctly.
I do not remove the foot and talus because it was not necessary to make changes to them as it was necessary with the shank and thigh. So I could keep foot and talus an did not need to add new ones.
Right now the calibration study and also the kinematics are running, which is good progress.
But a new error appears when starting the inverse dynamics. The error says, that the muscle recruitment solver is aborted due to a singular KKT-matrix and I really cannot figure out where exactly the problem is and how I could fix this.
As last time I would also put my current model in the dropbox folder you can access through this link:
Maybe you again have an idea what could lead to this error.
Many thanks and best regards
John
