  #1
Old 12-06-2012, 12:27 PM
thomaz thomaz is offline
Senior Member
Default create Model view from AnyBodyCon.exe
i like AnyBodyCon.exe very much. Sometimes, however, after having used it for a large number of jobs, i would like to inspect the results graphically. It would thus be very helpful if a model view could be exported from within AnyBodyCon.
This would however mean that also the view parameters (background color, perspective, which entities are visible etc.) can be defined within AnyBody.
Thomaz
  #2
Old 12-07-2012, 10:16 AM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
Hi Thomaz,
Just a small comment which i guess you already know.
If you save the .h5 output file then you can use it for replaying the model afterwards in AMS.
__________________
  #3
Old 12-07-2012, 10:21 AM
Senior Member
Default
Hi Søren,
thanks. Can the h5 file be saved from within AnyBodyCon?
I think i will have to have a look how to work with this file. I would like to concatenate several h5 files containing each a static analysis with nStep=1.
Thomaz
  #4
Old 12-07-2012, 10:36 AM
toerholm's Avatar
AnyBody Support
Default
Hi Thomaz,
Yes this should be possible,
From the the InverseDynamic.any file in the C3DProject model i have found these lines.
Code:
AnyOperationMacro SaveResults = {
MacroStr={
"classoperation Main.Studies.InverseDynamicStudy.Output" + " " + strquote("Save data") + " --file=" + strquote(FilePathCompleteOf(Main.ModelSetup.FileNames.Results )) + " --type=Deep"
So add something similar to your model and execute the operation from the console or add the operation above to the operation you are already executing.
Then all output data are saved... and you can later extract graphs or use it for replay
__________________
  #5
Old 12-07-2012, 10:52 AM
toerholm's Avatar
AnyBody Support
Default
Hi Thomaz,
One more comment, you can also use the camera class in the console application to make pics of the model.
See for example http://forge.anyscript.org/gf/snippe...etBrowse&id=18
__________________
Tags
export, model view, png
