Go Back   Forums Anyscript.org > Self-Supported Forum > AnyBody Model Repository
  #21
Old 03-02-2015, 08:25 AM
Senior Member
Default
Here is a general description of AnyBody:
http://wiki.anyscript.org/index.php/...ion_of_AnyBody
AnyBody uses inverse dynamics:
Input: motion or posture (+ external forces)
Output: Muscle activations, muscle forces, joint reaction forces, ...
__________________
Best regards, Amir
__________________
  #22
Old 03-18-2015, 11:59 PM
aahmadi aahmadi is offline
Junior Member
Default
Is it possible for this software to give dynamic bite force for the mandibular as an input and get the muscle force? I mean by dynamic biting force as a input, can we have reliable output from the software?
In most of the simulation related to mandible, only static forces were considered and there is no data for validating such dynamic force that can be considered for mandible. So How much the output of software can be acceptable by this assumption?
  #23
Old 03-19-2015, 03:42 PM
Senior Member
Default
Good question. If there is no data available for validation, so how can you know that it is acceptable or not. Maybe some of the other guys here have a thought on it.
__________________
Best regards, Amir
__________________
  #24
Old 03-19-2015, 07:50 PM
Junior Member
Default
you're right. So without considering verification, I want to know that it is possible to give dynamic biting force as input and get the result?
  #25
Old 03-20-2015, 08:21 AM
markdezee markdezee is offline
Junior Member
Default
If you have the data, the model would be able to handle a dynamic biting force as input.
The challenge is to get the experimental data. It is for example really difficult to measure the distribution of the forces on the molars and the incisors during chewing. So I think it is an experimental problem and not a model problem.
Greetings, Mark
