Go Back   Forums Anyscript.org > Self-Supported Forum > AnyBody Model Repository
  #1
Old 07-19-2014, 03:52 PM
khushbupatel494 khushbupatel494 is offline
Junior Member
Default Changing the Time Axis
How do you change the amount of time that the inverse dynamic analysis runs for?
  #2
Old 07-21-2014, 10:10 AM
Senior Member
Default
it depends if it is a motion capture driven model, then the time comes form the recording and cannot be changed easily.
if it is a paramterized model you can just edit in the study:
tEnd = 360;
nStep = 101;
__________________
Best regards, Amir
__________________
  #3
Old 08-01-2014, 10:39 PM
Junior Member
Default
Thank you so much!
