  #11
Old 11-11-2014, 11:47 PM
vikaskaul vikaskaul is offline
Member
Default
Quote:
How big a difference do you see?
From being indiscernible (model markers overlapping experimental markers) in the first part to being clearly separated by, at most, a few centimeters in the second part.
  #12
Old 11-12-2014, 02:04 PM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
Hi Vikas,
I have double checked the standard model, and it has revealed a small error in the visualization of the marker trajectory ball for the inverse model, so the blue sphere. The error is only visual and results from the model is not changed.
To correct it please localize the CreateMarkerClass being used to create the marker.
Then replace the "AnyDrawVector MarkerName" object in this class with this code:
Code:
AnyDrawSphere MarkerName={
Visible=On;
Opacity=0.5;
Position={Main.ModelSetup.C3DFileData.Points.Markers.MarkerName.PosInterpol(Main.Studies.InverseDynamicStudy.t)}[0];
 GlobalCoord=On;
ScaleXYZ={1,1,1}*0.01;
RGB={0,0,1};
AnyRefFrame&Globalref=Main.Studies.InverseDynamicStudy.EnvironmentModel.GlobalRef;
If you still see errors please try to use more timeframes in both studies, maybe also try to use higher nStep for kinematic analysis than inverse for example a factor 2. Both of these approaches will decrease the influence of the interpolation error introduces by the drivers.
__________________
  #13
Old 11-12-2014, 05:51 PM
Member
Default thanks
Hi Søren,
Thank you. As soon as I find some time to revisit this, I will make the suggested changes and post my feedback here.
Best,
Vikas
  #14
Old 10-20-2017, 01:56 PM
MMMPPPMMM MMMPPPMMM is offline
Member
Default
Quote:
Originally Posted by aalmunajjed View Post
Hi Vikas,
In a MoCap driven model, the residual force can be found in the ModelEnvironmentConnection:
Main.Studies.InverseDynamicStudy.Output.ModelEnvir onmentConnection.JointsAndDrivers.JntDriverTrunk.R eaction.Fout
Hello
Why is this a vector with 9 elements?
How do I calculate the resultant residual force with this vector?
Thanks in advance
__________________
AnyBody version : 7. 1. 2. 6044
  #15
Old 10-23-2017, 11:17 AM
toerholm's Avatar
AnyBody Support
Default
Hi Fritz,
Please have a look at driver:
Code:
AnyKinEqInterPolDriver JntDriverTrunk = {
    FileErrorContinueOnOff = On;
    Type = Bspline;
    BsplineOrder = 4;
    FileName = "../Input/"+OutputFileNamePrefix+Main.ModelSetup.C3DFileData.NameOfFile+"-euler-trunk.txt";
    AnyKinMeasureOrg &PelvisPosX = ...BodyModel.Interface.Trunk.PelvisPosX;
    AnyKinMeasureOrg &PelvisPosY = ...BodyModel.Interface.Trunk.PelvisPosY;
    AnyKinMeasureOrg &PelvisPosZ = ...BodyModel.Interface.Trunk.PelvisPosZ;
    AnyKinMeasureOrg &PelvisRotX = ...BodyModel.Interface.Trunk.PelvisRotX;
    AnyKinMeasureOrg &PelvisRotY = ...BodyModel.Interface.Trunk.PelvisRotY;
    AnyKinMeasureOrg &PelvisRotZ = ...BodyModel.Interface.Trunk.PelvisRotZ;
    AnyKinMeasureOrg &PelvisThoraxExtension = ...BodyModel.Interface.Trunk.PelvisThoraxExtension;
    AnyKinMeasureOrg &PelvisThoraxLateralBending = ...BodyModel.Interface.Trunk.PelvisThoraxLateralBending;
    AnyKinMeasureOrg &PelvisThoraxRotation = ...BodyModel.Interface.Trunk.PelvisThoraxRotation;
    #if TRUNK == 1
    AnyKinMeasureOrg &NeckExtension = ...BodyModel.Interface.Trunk.NeckJoint;
    Reaction.Type={On,On,On,On,On,On,Off,Off,Off,Off};
    #endif
    #if TRUNK_NECK == 1
    AnyKinMeasureOrg& SkullThoraxFlexion = ...BodyModel.Interface.Trunk.SkullThoraxFlexion;
    AnyKinMeasureOrg& SkullThoraxLateralBending = ...BodyModel.Interface.Trunk.SkullThoraxLateralBending;
    AnyKinMeasureOrg& SkullThoraxRotation = ...BodyModel.Interface.Trunk.SkullThoraxRotation;
    Reaction.Type={On,On,On,On,On,On,Off,Off,Off,Off,Off,Off};
    #endif
The vector has 9 elements but only the first 6 of them can be non-zero, since the rest has been switched off.
By default all drivers has reactions which are on until they are disabled, and size of the reactions listed will always be the size of the driver
__________________
  #16
Old 11-17-2017, 11:10 AM
Member
Default
Thank you.
Am I right that the PelvisPosZ is the residual force of the transverse axis (left 2 right direction)?
Or does it depend on the global CS? Since in my case: Gravity = {0, 0, -9.81} instead of {0, -9.81, 0}
Kind regards
__________________
  #17
Old 11-20-2017, 03:50 PM
toerholm's Avatar
AnyBody Support
Default
The PelvisPosZ is the position with respect to the global system, so it depends on the orientation in the model.
I would visualize the the global coordinate system to see this e.g.
AnyFixedRefFrame MyGlobalRef ={
AnyDrawRefFrame drw ={};
__________________
