Go Back   Forums Anyscript.org > Professional Forum > AnyBody Exporter for SOLIDWORKS
  #1
Old 04-13-2015, 07:04 PM
hayajneh hayajneh is offline
Junior Member
Default SolidWorks2AnyBody
Dear Dr. Jung,
I already installed Solidwork2Anybody and I initialized the add-in, but once I hit the Solidwork2Anybody option in SolidWorks program, it gives me nothing. Also, the help option in the same add-in is not working!
Please, let me know what to do to solve this problem.
Sincerely,
Hassan.
  #2
Old 04-16-2015, 02:54 PM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
Hi Hassan,
Sorry about the trouble,
In order for us to help you, please let us know the following:
  1. Which version of SolidWorks are you using?
  2. Please provide a few screendumps of what you are doing
__________________
  #3
Old 04-16-2015, 06:09 PM
Junior Member
Default
Mr. Soren,
1- I am using SolidWorks 2014 x64 Edition.
2- I am trying to import the attached file [picture] to the human model in AnyBody.
Sincerely,
Hassan
  #4
Old 04-17-2015, 09:48 AM
toerholm's Avatar
AnyBody Support
Default
Hi Hassan,
Thanks for the info,
Please try to attach the picture again i could not see this, we would like to have picture displaying the menu item with the add-inn
Also please describe exactly what happen if anything when you press the menu item.
__________________
  #5
Old 04-17-2015, 07:59 PM
Junior Member
Default
Mr. Søren,
Please try to find the attached pictures.
On the other hand, the basic problem with my case that I am trying to import the attached model or frame from SolidWorks to AnyBody, but unfortunately once I hit [Solidwork2Anybody] it is not responding and gives nothing, also even the [Help] option gives me this message: "AnyScript Reference Manual Was Not Found!].
Sincerely,
Hassan
  #6
Old 04-20-2015, 03:12 PM
mkjung9980's Avatar
Senior Member
Default
Dear Hassan,
SolidWorks2AnyBody only works when you are working with SolidWorks assembly models, not a single part.
The reason is that for single SolidWorks part, you can just save its geometry as STL file and extract its mass property using proper SolidWorks GUI.
__________________
  #7
Old 04-20-2015, 06:26 PM
Junior Member
Default
Many Thanks Dr. Moonki, I will try to have the frame as an assembly.
Sincerely,
Hassan
  #8
Old 04-30-2015, 12:06 AM
Junior Member
Default
Good Day All,
I am trying to attach a very simple frame with two joints to the human model, but every time it keeps giving me an error message! I attached the SolidWorks files and the AnyBody files in here for your reference. So please let me know how can get it done.
Sincerely,
Hassan
  #9
Old 05-05-2015, 10:11 AM
mkjung9980's Avatar
Senior Member
Default
Dear Hassan,
First, you should simply the mates in your SolidWorks model.
It seems that now you have 3 parts in your assembly.
Then I would suggest you to use 2 hinge mates instead of your current mates.
After translating your SolidWorks model into AnyScript model,
then you should create some constraints between your parts and AnyBody human model.
__________________
  #10
Old 07-13-2015, 01:09 AM
Junior Member
Default
Dear AnyBody Team,
Attached is my simple exoskeleton model, two links and one revolute joint. every time i am trying to run the model, it gives me an error due to the initial conditions.
So, could you please help me to solve this problem?
Also, for a comparison issue, i am attaching another model done by Dr. Jung and it was working.
Sincerely,
Hassan
