Go Back   Forums Anyscript.org > Professional Forum > AnyBody Exporter for SOLIDWORKS
  #1
Old 03-20-2016, 08:31 AM
alishokshok1969 alishokshok1969 is offline
Junior Member
Default Hand pump Model
Hi All , where can I find Hand pump Model. I couldn't find it
  #2
Old 03-22-2016, 08:41 AM
Junior Member
Default
Hi, All I found the Hand pump model in old versions of AMMR, but when I run it , stop and give the message Number of elements in type specification must match number of elements in force vector (num. elem = 1)
My version is 6.0.1.3928
pls. Haw can I open this model
  #3
Old 03-23-2016, 09:38 AM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
This model has been discontinued, so we do not have and updated version to provide.
This error means that the mismatch between the number of elements in the measure and the number of reactions/force been added... please try look at the measure and adjust the number of reactions/force so that they match in dimensions... so if the measure has two components the force needs to have it too...
__________________
  #4
Old 04-14-2016, 11:08 AM
Junior Member
Default
Thank you for answering
