  #1
Old 05-09-2017, 05:25 PM
tjwjdal tjwjdal is offline
Junior Member
Default observing the sagittal knee joint torque
Good morning. I am currently observing the knee with the following model.
(Since we created the motion separately, please
do not proceed with "MotionAndParameterOptimizationModel".)
In order to observe the sagittal knee joint torque I am looking following path.
Main.Studies.InverseDynamicStudy.Output.BodyModel. *(Left or Right). Leg.Jnt.Knee.Constraints.Reaction.RefFrameOutput.M [0] [2]
But the patterns and values are strange.
I doubt the following, but I do not know the exact answer.
- Is there a problem with the Joint drivers?
- Is the moment in the y direction (M [0] [1]) is sagittal torque??
- Is the above path inadequate to observe Joint Torque?
I will be waiting for your reply.
Always Thank you.
  #2
Old 05-10-2017, 09:01 AM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
I have been unable to run the model i think you have modified the forceplate class and provided it.
The property you are looking at is the moment in the reference frame , measured in global. I think you will also see that the two moments have the same values but differences in signs.
__________________
  #3
Old 05-10-2017, 09:25 AM
Junior Member
Default modified file
I'm really sorry.
So I attached other file using real data.
You mean that the sagittal moment will be M [0] [0] (on the x-axis moment), because it use grobal coordinate.
But I think this result is too small.
Therefore, I think there is a problem with my model.
And the following path is different from the joint torque?
Main.Studies.InverseDynamicStudy.Output.BodyModel. Right.Leg.MomentMeasure.KneeNetMomentMuscle.M (or Mlocal)
Sorry to trouble you.
Thank you.
  #4
Old 05-15-2017, 11:24 AM
toerholm's Avatar
AnyBody Support
Default
I have tested the model and it gives a max moment of 37Nm in the knee running with no muscles..
The moment has six components.
Ref frame 1 : Mx,My Mz global
Ref frame 2 : Mx,My Mz global
Please have a look in the book "Dynamics of Human Gait" by Christopher L Vaughan, for a good references on actual values.
__________________
  #5
Old 05-15-2017, 12:30 PM
Junior Member
Default Where can I get the value?
Thank you for your reply.
I'm sorry, but I would like to ask you once more that it confused.
Where can I get the value of 37Nm?
The reaction moment (Main.Studies.InverseDynamicStudy.Output.BodyModel .Right.Leg.Jnt.Knee.Constraints.Reaction.RefFrameO utput.M) of the knee shows that the maximum value in the sagittal direction is -2.66Nm and the maximum value in the coronal direction is 15.8Nm.
Where can I get the value of 37Nm and what is the direction?
  #6
Old 05-15-2017, 12:36 PM
toerholm's Avatar
AnyBody Support
Default
The 37Nm applies to the left leg, you are correct about the right knee it was about 15 Nm
__________________
  #7
Old 05-15-2017, 02:32 PM
Junior Member
Default But still questions remain.
I checked both the moment of the left leg and the book that you informed.
37 Nm means moment of coronal (adduction) direction.
The moments of sagittal direction(flexion/extension) are still very small.
In that book, Sagittal and Coronal moments are not much different.
So I wander why the result of this model is wrong.
  #8
Old 05-15-2017, 02:41 PM
toerholm's Avatar
AnyBody Support
Default
Ok now i understand the question.
The moments you are looking at in the joint are the reaction moments in the revolute joint. So these moments do not represent the flexion extenstion because this moment is the only free DOF in this joint. So you will not see any reaction relating to flextion extension if this is what you are looking for.
This model has no real muscles, so in in this model there are some joint muscles which carries the applied loads, please look at the JointMuscles folder in the leg model, it will have two muscle for each dof one in positive direction and one in negative dirction.
__________________
  #9
Old 05-16-2017, 05:20 AM
Junior Member
Default I found it.
Is that what you mean? I found it.
Really thank you so much.
  #10
Old 05-16-2017, 09:04 AM
toerholm's Avatar
AnyBody Support
Default
yes ;-)
__________________
