  #11
Old 06-15-2017, 09:50 AM
pgalibarov's Avatar
Senior Member
Default
Hi Fatemeh,
Good to hear. Everything works for me when I try to include into StandingModel. You should simply include the MyScalingLaw.any before the human model is included. And it will just work:
Code:
  // INCLUDE BEFORE #include "HumanModel.any"
  #include "YOUR_PATH_TO_SCALING_FOLDER/Scaling/CustomScaling.any"
  // Model of the human body to be used for the analysis
  #include "<ANYBODY_PATH_BODY>/HumanModel.any"
Please do not modify HumanModel.any, we will not be able to support you if something changes there.
  #12
Old 06-15-2017, 10:57 AM
f.s.alavi f.s.alavi is offline
Junior Member
Default
Pavel,
Many Thanks for your effective help.
Best wishes,
Fatemeh
  #13
Old 06-19-2017, 09:30 AM
Junior Member
Default
Hi Pavel,
I ran MoCap-Runner.main.any. I tried to convert forces to Abaqus. Everything seemed OK, but in the last step, when I ran AnyFE2Abq.exe, the error occurred, which said your .xml file may not have correct format.
when I opened .xml file by notepad, it sounded Ok but in internet explorer, it looked incorrectly.
I attached all files.
Fatemeh
  #14
Old 06-22-2017, 11:24 AM
pgalibarov's Avatar
Senior Member
Default
Hi Fatemeh,
Looks like the XML file is somehow broken. Have you tried regenerating it? I can't really say what caused it from the information you gave and how to fix it.
I get a similar behaviour, but it seems that the XML format is broken. Do you think you could shorten the simulation output somehow? It looks like a very large file and I can't really check it to find a problem in XML tags.
