  #11
Old 09-11-2017, 05:03 PM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
Hi FeliceLP,
The reaction needs to be off, otherwise the head carry the phone to some extent.
When you are saying it wrong what are you comparing it with?
__________________
  #12
Old 09-12-2017, 10:18 AM
FeliceLP FeliceLP is offline
Junior Member
Default
Hi Søren,
Your suggestion has been very helpful and I was wrong.
I have to simulate a Force and I'm thinking how (to simulate tapping).
Sorry for my misunderstanding.
I have tried to use AnyForce3D (constant to start)
on the thumb but unfortunately
the activity doesn't seem to change.
I'm using experimental measurements (EMG and %MVC).
Felice.
  #13
Old 09-12-2017, 10:23 AM
toerholm's Avatar
AnyBody Support
Default
Hi Felice,
AnyForce3D applied in the tip of the thumb sounds correct.
Please try to add a large force to test if you can see changes, it should change the results.
__________________
  #14
Old 09-12-2017, 10:29 AM
Junior Member
Default
Hi Søren,
I'm trying in this moment and using an enormous Force the model
muscle's result overloaded.
The strange thing is that muscles like extensors and abductor of
the thumb show e^-10 order activity and they are the muscles I
want to study principally.
I think reactions are always the problem. I'm using reactions
on the tip of Finger3, Finger 4 (back of the phone).
I have to switch on reactions on the thumb's tip driver?
Thank you for reply
Felice
  #15
Old 09-14-2017, 10:10 AM
toerholm's Avatar
AnyBody Support
Default
Hi Felice,
I am just guessing now, the spherical joint connecting the phone which segments on the hand does it connect to?
I did not understand this with the thumb muscles (extensors and abductor)... the model has only torque generators for the finger joints the "real" muscles does not span the finger joints this is a simplification.
__________________
