  #1
Old 08-08-2017, 09:38 AM
victorwambugu victorwambugu is offline
Junior Member
Default FEA interfacing
I am going through the FEA interfacing tutorial and was wondering if there are any changes that one should make on the StandingLiftFEA.main file before running the inverse dynamic analysis because I can't seem to generate an output file once the inverse dynamic analysis is complete.
Im checking for the output file in the applications folder in the AMMR folder.
Victor
  #2
Old 08-08-2017, 10:04 AM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
Hi Victor,
I have just tested the StandingLift/StandingLiftFEA.main.any file in the repository, and it worked fine.
The output file is generated in the "Output" folder
__________________
  #3
Old 08-10-2017, 05:12 AM
Junior Member
Default
Hi Soren,
I got it, thanks.
Victor
