  #1
Old 08-15-2017, 11:32 AM
victorwambugu victorwambugu is offline
Junior Member
Default Standing lift model
Hello AnyBody,
I would like to generate an output file much like the one from the standinglift FEA main file in the tutorial to study. How do I do this with the standing human template? Is there a way of deleting the aquarium and using the standing lift model instead? I have tried this and get lots of error messages.
I just want to alter the joint angles and generate an output file of the forces on the L4,L5.
Victor
  #2
Old 08-15-2017, 01:05 PM
pgalibarov's Avatar
Senior Member
Default
Hi Victor,
Normally you would just copy relevant blocks of code, insert into the new model, and adjust references/paths if they somehow differ.
Could you try doing it? If you get stuck you could post what your actual problem is.
  #3
Old 08-16-2017, 08:31 AM
Junior Member
Default
Hi Pavel,
Thank you for your response.
I did as you suggested (copied the relevant blocks of code) and was able to load the model. However, when I try to run the Inverse dynamic analysis I get an error in the study folder:
ERROR(OBJ.MCH.KIN2) : C:/U..s/w..g/D..s/A..y/F..l/s..n/standing human.main.any(40) : Study : Model is kinematically over-constrained : Position analysis failed : 8 unsolvable constraint(s) found
Victor
  #4
Old 08-16-2017, 01:07 PM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
Hi Victor,
The error indicates that you have 8 kinematics constraints too many.
So it looks to me like you have added 8 constraints to the standing model but you may not have removed any constraints?
Please explain exactly what you have done
1 basis model ?
2 Added coded?
3 Removed coded?
__________________
  #5
Old 08-17-2017, 05:27 AM
Junior Member
Default
Hello Soren,
I did 2 (added code). I copied the output generating code from the standing lift FEA model onto the standing human Study folder. I have put the section of code at the end of the text. Just in case.
My aim is to generate an output file from the standing human model for use in FEA. I did not change the other folders.
Victor
AnyBodyStudy Study = {
AnyFolder &Model = .Model;
tEnd=1;
Gravity={0.0, -9.81, 0.0};
nStep = 1;
// #ifndef FEA_OUTPUT
// default values for the StandingLift example
// tEnd = 1.0;
//nStep = 30;
//#else
// single step for the StandingLiftFEA example
// tStart = 0.5;
// tEnd = 0.5;
//nStep = 1;
AnyMechOutputFileForceExport ForceOutput =
FileName = "Output/ForceL5.txt";
/*NumberFormat =
Digits = 15;
Width = 22;
Style = ScientificNumber;
FormatStr = "";
AnySeg &L5Seg = Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.L5S eg;
// #endif
#include "Model\RunAppSequence.any"
  #6
Old 08-28-2017, 05:45 PM
toerholm's Avatar
AnyBody Support
Default
Hi Victor,
Sorry for the slow reply,
I can not see why the code you have listed would cause a kinematic problem, in my view it must be something else which has been changed.
Please try to out-comment your added lines and verify that the model runs?
__________________
  #7
Old 09-04-2017, 07:17 AM
Junior Member
Default
Thanks Soren,
I will do as you have suggested
Victor
