  #11
Old 02-01-2018, 10:31 AM
mewael mewael is offline
Junior Member
Default
Hallo Pavel,
Thx a lot for your helpful reply. Unfortunately I didn't notice your reply until now.
I understand now how to make a transformation from local to global CS, but I'm not sure how to find the the torque around the axial axis of the femur.
I did it using the muscle forces, which go through the femur. As a reference frame I used the femur itself. So I'm not sure if that the right way to get the torque.
I would appreciate it if you could tell me if this the right way to do it.
Wael
  #12
Old 02-01-2018, 11:47 AM
pgalibarov's Avatar
Senior Member
Default
Dear Wael,
I may be misunderstanding something. But I will refer back to the previous code:
Code:
AnyForceMomentMeasure2 MomentMeasureLoc =
      AnyVec3 Mlocal=M*ref.Axes;
      AnyVar AxialTorque=Mlocal[2]; // Z torque
 // defines the axial axis, Z aligned with the axis
AnyRefFrame &Ref = Main.CanineModel.Segs.Right.Femur.NodeOfInterest;;
AnySeg &Seg = Main.CanineModel.Segs.Right.Femur;
AnyFolder &Mus1 = Main.CanineModel.Muscles.Right.Vastus_lateralis_in termedius;
AnyFolder &Mus2 = Main.CanineModel.Muscles.Right.Vastus_medialis;
AnyFolder &Mus3 = Main.CanineModel.Muscles.Right.Adductor_magnus;
AnyFolder &Mus4 = Main.CanineModel.Muscles.Right.Gluteus_medius_caud alis;
As a result you will get the torque about Z axis (your axial axis), generated by specified muscles. You just need to define NodeOfInterest to be on the relevant axis and Z pointing in the needed direction.
Code:
Main.CanineModel.Segs.Right.Femur = {
  AnyRefNode NodeOfInterest = {
    sRel = {...}; // coordinates of a point on the axis
    ARel = {...};// rotation matrix to align Z axis, please read about RotMat functions
If that does not make sense - you could try a simple example and check your variation of this code works.
  #13
Old 02-01-2018, 12:13 PM
Junior Member
Default
Hallo Pavel,
perfect. That's exactly, what i wanted to know.
Thank you so much
Best Regards
Wael
