  #1
Old 12-08-2017, 11:03 PM
johnwu johnwu is offline
Junior Member
Default Kneeling model
Hi AnyBody,
I just start build a kneeling model by modifying existing SeatedHuman. In the experiments, we have the kinematics of whole body and the interface pressure between the knee and floor. I wish predict the knee contact pressure and to compare it with the test data.
I think the interaction between the floor and knee is not correctly built and need your help. Also, I need your help to add contact force on the soft tissues in thigh.
John
  #2
Old 12-13-2017, 02:29 PM
pgalibarov's Avatar
Senior Member
Default
Hi John,
The easiest way to add those contact elements is to have a look at how it is implemented in the SeatedHuman model.
The conditional contact is defined between the backrest and the spine - you may want to copy and adjust this code for the shank segments. You are probably aware of the logic there - the expected contact nodes are defined on the shank segments, and pushing muscles are added between these nodes and objects representing the floor.
Please have a look at, say:
ammr\Application\Examples\SeatedHuman\Model\SeatSu pport.any
Similarly, you could add conditional contact between two segments by defining expected contact nodes on, for example, thigh and introducing pushing muscles to the shank.
In my opinion this is the easiest that could be done.
Please let me know if that is clear and you have any further questions.
  #3
Old 01-24-2018, 12:12 AM
Junior Member
Default
I am still working on my kneeling model.
1. I have modified the existing Standing model to fit my purpose.
2. I am driving the model via joints using my test data.
3. I have here one problem: it seems I can drive the shoulder and elbow joints, but not the knee and ankle joints.
  #4
Old 01-24-2018, 10:37 PM
Junior Member
Default
I think I figure out the problem: I have put drivers on wrong places.
  #5
Old 02-02-2018, 12:54 AM
Junior Member
Default
Hi AnyBody,
I need your help to find out problem in my model. I am still working on my kneeling model. The model works in kinematics, but it fails in inverse dynamics. It makes muscle recruitment error, even I switch off all muscles.
John
  #6
Old 02-05-2018, 08:37 PM
Junior Member
Default
Pavel,
I am still struggling with the model. Now, I have simplified the model to include only one leg. The model works. But, it does not work with both legs on.
John
File Type: zip KneelingModel_one_leg_trial2_anybody.zip (2.80 MB, 1 views)
Tags
ammr_v2, anybody_v7, kneeling model
