Go Back   Forums Anyscript.org > Professional Forum > AnyBody Exporter for SOLIDWORKS
  #1
Old 02-06-2018, 03:56 PM
ic-winnik ic-winnik is offline
Junior Member
Default Insert an implant from SolidWorks into the HumanModel
Iím currently trying to insert a femoral and a tibial component into the standing human model.
I first tried to insert the Implants by stl-files, like it was done in the THA- and TKA-Model, direktly into the KneeJointAnatomicalFrame. The insertion worked, but since it is a coupled Knee Joint, I needed to join the components with a spherical Joint. But itís not possible to include nodes or something to create a connection.
Thatís why I decided to do it with SolidWorks. Both components arenít overconstrained. I inserted them into the StandingHumanModel, but they are stitched to the GlobalRefFrame, even when I insert them directly into the Implant-Node in the KneeJointAnatomicalFrame. I tried to comment out the GlobalRefFrame in the AnyScript-file of the component and attached the Origin_Ref of the implant to the ImplantNode.
I tried a lot, but the component is still attached to the origin of the GlobalRefFrame. I also loosened the fixation of the component to the Origin in SolidWorks, but when I include the file, the component is in the same position relativ to the origin as it was in the SolidWorks-file.
Is there something Iíve overlooked? I hope my problem is clear.
Thanks a lot for the help and best regards,
Kathrin
  #2
Old 02-06-2018, 04:45 PM
pgalibarov's Avatar
Senior Member
Default
"But itís not possible to include nodes or something to create a connection. "
Why? I don't see why it should not be possible.
  #3
Old 02-06-2018, 04:51 PM
Junior Member
Default
I added the Node into the AnySurfSTL-class and I got this error:
ERROR(SCR.EXP0) : C:/U..s/k..k/D..s/A..x/A..t/F..l/M..l/implants.any(16) : 'SphericalJointNode' : Error in expression. Please refer to the following error messages for details ...
ERROR(OBJ4) : C:/U..s/k..k/D..s/A..x/A..t/F..l/M..l/implants.any(16) : SphericalJointNode : Wrong owner class for AnyRefNode. Accepted owner: AnyRefFrame or derived
Model loading skipped
So it's not possible to insert a node into the stl-object, is it?
  #4
Old 02-13-2018, 03:09 PM
pgalibarov's Avatar
Senior Member
Default
Hi Kathrin,
Yes, please make a segment that corresponds to this STL and add the STL object and nodes to this segment.
