  #1
Old 12-31-2013, 01:56 AM
sts07009 sts07009 is offline
Junior Member
Default Issues in Coordinate Systems ( MOCAP and ANYBODY)
We have MOCAP data with a person in a recumbent position. The X-axis is chest to back and the Z- axis is butt to head. We need to change the ANYBODY model to reflect the same orientation. Then, we need to place the three markers on the acromion, lateral epicondyle and styloid process. As a result, the right arm of the ANYBODY model should follow the movement from the C3D file.
Please be of assistance.
Additionally, is there literature and/or videos that can help train a greenhorn to the ANYBODY application? The tutorials do not use the mannequin, so(hands in the air).
Thank you!
  #2
Old 01-02-2014, 07:05 PM
danielnolte danielnolte is offline
Senior Member
Default
Hi Stephany,
I had a look at the model you uploaded, but unfortunately the file baseline.main.any is missing, so a bit difficult to say something. Could you upload that file?
Daniel
  #3
Old 01-06-2014, 06:28 PM
Junior Member
Default
Hi Daniel,
Thanks for your reply. I apologize for not attaching the file in the first upload. I have uploaded it here.
Thank you for your help
  #4
Old 01-07-2014, 01:29 AM
Junior Member
Default Updated progress
Hi Daniel,
I have changed my approach to a modification of the example file MoCap FullBody. I have been able to have the model on his back in a relatively correct initial position. I am trying to essentially have only the right arm move based on input from the C3D mocap data. Everything else is static. I also do not have any force plates, so I just commented out that portion of the AnyBodyScript in the Environment.any file.
My issue lies in configuring the drivers. I seem to be missing 17 drivers, and I do not think I properly indicated that only the right arm is driven by the C3D data. There are other issues as well, such as the fact that the global coordinate system is not the same as the mocap data, and that certain body parts have not been grounded (such as the heels, buttocks and shoulder blades), but that wouldn't necessarily contribute to my issue with the drivers, would it?
Thank you so much for your help. This is my first time using AnyBody. Even after completing all of the tutorials there are still basic concepts I am missing.
The file is attached. Thanks again
  #5
Old 01-07-2014, 10:13 AM
Senior Member
Default
Hi Stephany,
I only had a quick look at your model, so I cannot give you a full solution to your problem.
There are several things you can do.
Since you are only driving the right arm, you could reduce your model to only having the trunk and the right arm and switch left arm and legs off using the BM statements.
Next, you removed all markers which include the drivers of the model. You have to replace these drivers by other drivers, which would be the pelvis, trunk, head and the rest of the arm if you can get rid of the other parts. I can probably modify drivers from the standing model and add them to your model.
As an example, you can also look at the model WheelChair Rancho from the repository. It is a model of a wheelchair driven by MoCap data. Maybe you could do similar things.
If you have the feeling that you have the feeling that you would like to know more about AMS, there is a PhD course at Aalborg University in spring. I think up to know there are still some vacant places left(PhD course on AnyBody). It is a great course given a good insight of techniques using AMS with a lot of hints and tricks which are difficult to get from only reading the tutorials. But you shouldn't wait too long, it has been booked up quite early the last years.
Daniel
  #6
Old 01-08-2014, 09:03 PM
Junior Member
Default
Hi Daniel
Thanks for your help! I will definitely try to implement your suggestions and look into the course.
I noticed that the MoCap example does not have a JointsAndDrivers.any file, but instead has ExtraDrivers.any. Are all of the drivers the model uses here then? Thus the modifications would be here as well? Or should I create a JointsAndDrivers.any file.
Also, does the Markers.any file create the driver so that that particular joint is driven by the motion of the marker?
  #7
Old 01-14-2014, 09:30 AM
Senior Member
Default
Hi Stephany,
the best way to figure out which drivers are there where they are located is to open the object description of the study (double-click the study in the model tree) which lists all DoF for the study and also the drivers. There you can have a look in the model which drivers are defined and using the links you can also figure out easily where to find them.
For the additional drivers, I would create a new file containing these, just to keep track of the changes you make.
Daniel
  #8
Old 01-28-2014, 06:52 PM
Junior Member
Default
In the Studies section where they list the drivers, there appear to be two types.
1) Main.Studies.HumanModel...
2) Main.Studies.KinematicStudyForParameterIdentificat ion...
Does this mean that the drivers categorized as group (2) are going to always be kinematically optimized every time I run the study? If this is the case, should everything that is not attached/driven by a marker be in group (1)?
I've attached an updated folder with my program if it helps.
  #9
Old 01-29-2014, 09:26 AM
Senior Member
Default
Unfortunately I cannot open your attached file. It looks somehow corrupted. Could you try uploading it again?
Daniel
  #10
Old 01-29-2014, 09:54 AM
Senior Member
Default
I cannot see the model, so I am just guessing what is in your model. But I assume that you have not done too many changes to the MoCap model.
The folder you mentioned as 1) is a folder containing the body model, i.e. all definitions of segments, joints, drivers etc.
The folder 2) is an AnyBodyStudy, i.e. an object that has an operation to perform an analysis with a given setting. This study contains a reference to the body model (if you are not familiar with references e.g. from C++ programming, you can think of it as an object pointing to another object so that you can use it the same way as it would be the original one; the same as shortcuts to folders on the Windows desktop). The study is performing the analysis on all objects that are defined in the study or referenced in the study.
In the MoCap model, you also find two folders more: ParameterIdentification and MotionOptimization. The MotionOptimization is quite similar to the KinematicStudyForParameterIdentification, so it is also an AnyBodyStudy just with slightly modified settings.
The ParameterIdentification is an OptKinStudy referencing an operation of the KinematicStudyForParameterIdentification. This Study is using the mentioned study to perform the optimization.
I hope this helps you understanding the model a little bit better. For more advice it would be helpful to see your model.
Daniel
Tags
c3d, coordinates, mocap, recumbent
