Go Back   Forums Anyscript.org > Professional Forum > Debug model
  #11
Old 11-27-2018, 01:04 PM
John John is offline
Hi Søren,
I thought that these muscles and old segments would not be involved anymore when starting the analysis because of the integrated exclusion in the inverse dynamic study.
If I now attach all muscles to the new bones, so that it looks like there is no amputation, will the muscles and objects that are part of the list with the objects that should be excluded still not get involved in the inverse dynamic analysis?
John
  #12
Old 11-27-2018, 02:54 PM
Hi John,
Sorry if i have misinterpreted the model, what i see is essentially all the muscles being excluded and left behind, except only a few muscle around the hip which has remained. So i concluded this was a mistake.
I do not see any muscle spanning the knee and ankle joint so unless you have torque generators in these joint it will fail to balance the model. I have looked to see if i could find these but i have not found them.
  #13
Old 11-28-2018, 12:26 PM
Hi Søren,
that is right, these few muscles around the hip that remain on the new leg represent the transfemoral amputation. That is also why there are no muscles spanning the knee and ankle joint anymore and all the other muscles and segments of the left side are excluded.
What you are noticing with the torque generators could maybe be really the problem, because I cannot remember that I generated something like this. So this will be a thing that needs to be checked.
Thank you very much for your new remarks!
John
