Go Back   Forums Anyscript.org > Self-Supported Forum > AnyBody Model Repository
Old 11-06-2014, 11:27 AM
jokarh65 jokarh65 is offline
Default L2L3 joint without degrees of freedom
hi
i want to fuse L2 and L3 seg so they act like a unique segment. is it possible to remove 3 rotational degrees of freedom of L2L3 joint or there is any other way to do this?
i think another way is to fuse L2 and L3 in a CAD software and import it into Anybody?
which one is the simplest way and how can i do that?
Old 11-06-2014, 12:19 PM
Dear Hossein,
Please have a look at the SpineFixationWithForceDepKinematics example. It exemplifies how one can change the kinematic spine rhythm (a combined driver for the whole lumbar spine) to use individual intervertebral angles.
I think you can either modify the rhythm to fix the joint or use the Force-Dependent Kinematics solver to find the position around the balance of all other joints based on muscular and external forces.
