Go Back   Forums Anyscript.org > Professional Forum > AnyBody Managed Model Repository
Old 06-17-2018, 12:30 PM
xunxiangerluo xunxiangerluo is offline
Default Access force at the specific motion angle during the parameter study
Hi,
I am studying the parameter study on the cervical spine. I tried to output the joint force at the specific motion angle, for example 1 degree. However, the value outputed by the AnyDesMeasure was the force at the end time. I found someone use the function argmin to realize the index of the minimum value in the previous thread. But I not only want to find the minimum, the force at specific angle (1°,2°,3°,4°...) could be outputed.
Code:
 AnyBodyStudy Study = {
AnyOutputFun Force = {
      Val = .Model.HumanModel.Trunk.JointsCervicalSpine.C5C4Jnt.Constraints.Reaction.Fout[0];
AnyOutputFun Angle = {
      Val = .Model.HumanModel.Trunk.JointsCervicalSpine.C5C4Jnt.Pos[0];
AnyParamStudy ParamStudy = {
AnyDesMeasure C5C4JntForce = {
      Val = ???..Study.Force();// the force at the specific C5C4Jnt angle
Thank you in advance.
Old 06-20-2018, 11:59 AM
mkjung9980's Avatar
mkjung9980 mkjung9980 is offline
Hi,
1) I would assume that you've seen our tutorial chapter for parameter studies:
https://anyscript.org/tutorials/Para...n/lesson1.html
2) Based on your code, it can be utilized like this:
Code:
    Val = min(..Study.Force());
But you need to define your own AnyDesVar objects inside your AnyParamStudy class instance.
3) But if you want to have the full history of the force at a specific parameter for your parameter studies,
it may be better to use external tool to test different parameters and hold all results for all different parameters.
I would recommend you to use AnyPyTools here:
https://anybody-research-group.githu...ocs/index.html
I hope that this may be helpful to you.
Moonki
Moon Ki Jung, Ph.D, Application Engineer, AnyBody Technology A/S.
※ AnyScript™ Reference Manual is the bible.
※ AnyScript™ wiki page is the best supplementary information(http://wiki.anyscript.org).
※ When you would upload your models, please write information about your AMS and AMMR versions.
※ If you want to get more intensive support, please update your information(profile, organization and signature).
