Go Back   Forums Anyscript.org > Professional Forum > AnyGait
  #1
Old 05-08-2017, 02:05 PM
bokku01 bokku01 is offline
Junior Member
Default The problem with using Helen Hayes marker set
Hello I am Bokku Kang from S.Korea.
I'm working with the anybody gait model, and would like to change the
marker set to the Helen Hayes marker set.
I wonder if there is ANYBODY standard model using Helen Hayes marker set. If not, I want to know how to change it. For example, we can move the marker's position, or change the marker's name etc.
I am looking forward to your reply.
thank you!!
  #2
Old 05-09-2017, 10:16 AM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
If you are using the MoCapModel then you can changes this in the Marker.any file, we do not have the Helen Hayes protocol, but it should be rather easy to do please see e.g.
https://github.com/AnyBody/support/w...p-driven-Model
If you are using the AnyGait model it is significantly more complex, and i do not have a simple answer for this.
__________________
  #3
Old 05-23-2017, 01:33 PM
Junior Member
Default
Thank you for your reply.
Your comment are very helpful for me.
