Old 05-10-2018, 05:56 AM
uricoco11 uricoco11 is offline
Default Making joint and motion
Hello.
I transfered the rigid body from solid works.
I want to apply translational motion (axis=x) to rigid body
so I wrote the below codes
AnyKinEqSimpleDriver AnkleLinDriver =
AnyKinLinear lin =
AnyRefFrame& ref0 = Main.MyModel.GlobalRef.basenode;
AnyRefFrame& ref1 = Main.seat_assem.seat_pan___1.Fix_Node;
Ref = 0;
MeasureOrganizer = {0}; //x
DriverPos = {0};
DriverVel = {2};
Reaction.Type = {On};
when I start kinematic analysis
the message ' Model is kinematically over-constrained' was occured
how can I fix it?
please check my file
thank you
Old 05-12-2018, 12:21 AM
Hi,
I looked at your previous model and you already have a fixation to the global ref. frame - try choosing just one:
Code:
  AnyFolder Mates =
      AnyKinEq Fix_seat_pan___1 =
        AnyKinLinear lin =
          AnyRefFrame& base = ....seat_assem.Origin_Ref;
          AnyRefFrame& target = ...seat_pan___1.Fix_Node;
          Ref = 0;
        AnyKinRotational rot =
          Type = PlanarAngles;
        CType = {.._ANY_CTYPE_, .._ANY_CTYPE_, .._ANY_CTYPE_, .._ANY_CTYPE_, .._ANY_CTYPE_, .._ANY_CTYPE_ };
Old 05-12-2018, 08:27 AM
[quote=uricoco11;22730]Hi.
I wrote '//' in front of the codes you said like below.
//AnyFolder Mates =
//AnyKinEq Fix_seat_pan___1 =
//AnyKinLinear lin =
//AnyRefFrame& base = ....seat_assem.Origin_Ref;
//AnyRefFrame& target = ...seat_pan___1.Fix_Node;
//Ref = 0;
//AnyKinRotational rot =
//Type = PlanarAngles;
//CType = {.._ANY_CTYPE_, .._ANY_CTYPE_, .._ANY_CTYPE_, .._ANY_CTYPE_, .._ANY_CTYPE_, .._ANY_CTYPE_ };
And I made joint and motion in 'Environment'
please check 'seat2.zip file' (not 'seat.zip')
As I think, you didn't check and open 'seat2.zip' file
when I start the kinematic analysis, the message(Model is kinematically over-constrained) was occured.
thank you
Old 05-12-2018, 07:47 PM
Hi,
You did not define your segment inside of the MyModel folder that is being included later in MyStudy, and, hence, the analysis is not aware of this particular segment.
It creates a situation when you provided a driver (1dof), but no segment. This is why the system gives an over-constrained error.
BUT! If you include this object like this:
Code:
  // The actual body model goes in this folder
  AnyFolder MyModel = {
    #include  "Model/seat_pan.any"
    // Global Reference Frame
    AnyFixedRefFrame GlobalRef = {
      AnyRefNode basenode ={};
      #include "Model\Environment.any"
    };  // Global reference frame
  }; // MyModel
  // The study: Operations to be performed on the model
  AnyBodyStudy MyStudy = {
    AnyFolder &Model = .MyModel;
This will create a situation, where the system is underconstrained. Because you created a single driver for 1 dof, but out-commented constraints for all other degrees of freedom. You need to provide another 5 constraints.
One way to do it is like this:
Code:
    AnyKinLinear lin =
      AnyRefFrame& ref1 = Main.MyModel.seat_assem.seat_pan___1.Fix_Node;
      Ref = 0;
      Type = RotAxesAngles;
    //MeasureOrganizer = {0}; //x
    DriverPos = {0, 0, 0, 0, 0, 0};
    DriverVel = {1, 0, 0, 0, 0, 0};
    Reaction.Type = {On, On, On, On, On, On};
This code makes the seat move in the X direction.
Old 05-19-2018, 08:39 AM
Thanks for your help
I made another model using your comments
I want to make the seat moved with human.
seating on the seat pan, the human can be moved in x-direction.
in 'seat_model_04.zip' file,
there is human model fixing with seat pan.
I made translational joint and motion in x-direction
when I start kinematic analysis, the error was bigger than default tolerance.
Please check my file.
thank you.
