Go Back   Forums Anyscript.org > Archive > AnyScript Message Archive
Old 03-19-2009, 11:54 AM
peter.worsley
Guest
Posts: n/a
Default POSVELACC optimisation
Dear AnyBody,
I am trying to do a comparison of optimisation methods available in
GaitApplication2. When trying to run the model on POSVELACC in the studygait.txt
file I am getting the following ERROR;
failed to read desired sample in marker file; (first time step) ; dummy.txt
I've checked the dummy.txt file and it is the same for my POSONLY and SCALE
optimisations which both work.
Any thoughts on why POSVELACC is failing would be greatly appreciated.
many thanks
Peter
Old 03-19-2009, 12:36 PM
Michael Skipper Andersen
Guest
Posts: n/a
Default RE: [AnyScript] POSVELACC optimisation
Hey Peter,
The answer is rather simple.
When you want to perform velocity and acceleration analysis as well, you need to
provide the time derivatives of the marker trajectories as input. If you look in
the reference manual for the GaitApplication2, you will see that in the MARKER
specification, after the filename with marker data, two additional filenames
should be provided, i.e. one with the velocity of the marker trajectories and
one with the acceleration of the marker trajectories.
Since we did not need these when performing position analysis and scaling
studies, we just put some dummy files (hence the name dummy.txt).
The format in these files should be the same as for the marker position data,
i.e. time x , y, z. The easiest way to obtain this data is to use the
interpostion functions in AnyBody, similarly to what was done for the marker
position data. Have a look in the MarkerMover.any file and construct two new
output file objects.
There is one thing that I should clarify, however. When you want to do velocity
and acceleration analysis, you need to specify a constant weight for the markers
(your weight.txt file) otherwise you will get incorrect results. It is simply an
interface feature that is missing (time-derivatives of the weight functions
cannot be provided yet), and noone has ever needed it so it has not had much
priority to implement it.
I hope that helps.
The AnyBody Research Project.
To: anyscript@yahoogroups.com
Date: Thu, 19 Mar 2009 10:54:27 +0000
Subject: [AnyScript] POSVELACC optimisation
Dear AnyBody,
many thanks
Peter
__________________________________________________ _______________
Drag n’ drop—Get easy photo sharing with Windows Live™ Photos.
http://www.microsoft.com/windows/win...ts/photos.aspx
[Non-text portions of this message have been removed]
Old 03-19-2009, 01:12 PM
Peter Worsley
Guest
Posts: n/a
Hey Michael,
I have outputed the velocities and the accelerations files for each marker, but
I am unsure on how to feed them into the model. Do I need to construct one
dummy.txt file with both the velocities and accelerations, and if so what order
does the data need to be in?
many thanks
Peter
--- On Thu, 19/3/09, Michael Skipper Andersen <msandersen60@hotmail.com> wrote:
From: Michael Skipper Andersen <msandersen60@hotmail.com>
Subject: RE: [AnyScript] POSVELACC optimisation
Date: Thursday, 19 March, 2009, 11:36 AM
Hey Peter,
to provide the time derivatives of the marker trajectories as input. If you look
in the reference manual for the GaitApplication2, you will see that in the
MARKER specification, after the filename with marker data, two additional
filenames should be provided, i.e. one with the velocity of the marker
trajectories and one with the acceleration of the marker trajectories.
I hope that helps.
Dear AnyBody,
many thanks
Peter
Users of the AnyBody Modeling System help each other create biomechanical
models in the AnyScript language.Yahoo! Groups Links
Old 03-19-2009, 01:23 PM
Guest
Posts: n/a
Hey Peter,
If you want it to be setup automatically in the same way you have for the marker
position data, you need to make the change in the DataForConfigFile.any file. In
that file there is a list of marker specifications with the keyword MARKER.
In the line for each marker, the dummy.txt file is written two times in a row.
In all those lines, you should replace the first dummy.txt filename with the
filename of the velocity data file for that specific marker and the second with
the acceleration data for the marker.
I hope that answers your question.
Date: Thu, 19 Mar 2009 12:12:14 +0000
Hey Michael,
many thanks
Peter
Hey Peter,
I hope that helps.
Dear AnyBody,
many thanks
Peter
News, entertainment and everything you care about at Live.com. Get it now!
http://www.live.com/getstarted.aspx
Old 03-19-2009, 02:55 PM
Peter Worsley
Guest
Posts: n/a
Hey Michael,
thankyou for your advice, everythings working fine now. I'm currently running a
monte-carlo variance study on markerpos and scaling inputs for the 2 types of
optimisation (SCALE, and POSVELACC) compared to unoptimised data. I will forward
you on the results once I have completed 1000 cycles.
best wishes
Peter
Date: Thursday, 19 March, 2009, 12:23 PM
Hey Peter,
marker position data, you need to make the change in the DataForConfigFile.any
file. In that file there is a list of marker specifications with the keyword
MARKER.
Hey Michael,
many thanks
Peter
Hey Peter,
look
markers
an
I hope that helps.
Dear AnyBody,
studygait.txt
many thanks
Peter
