Go Back   Forums Anyscript.org > Archive > AnyScript Message Archive
  #1
Old 03-10-2009, 02:07 AM
Jean-Olivier Racine
Guest
Posts: n/a
Default Wrong orientation when driving model
Hello guys,
As some of you may know, I am working on a sit-to-stand model. My model is
based on the old Gait model (lower-limb) and uses orientation to drive the
segments. In short, I drive the thigh (3 DOFs x 2) and pelvis (3 DOFs)
segments using data files that contain rotation vectors over time, and I use
angles to drive the shank (knee, 1 DOF x 2) and feet (ankle, 2 DOFs x 2)
(time + 3 components) and I position the center of the pelvis (3 DOFs).
My problem is that the orientation of the segments do not match the
orientation I supply. More specifically, if I measure (using a
AnyKinRotational) the orientation between the global reference frame and the
thigh segment, I get a different result than if I look at the measure/driver
used to drive this very segment.
Here are extracts from the model code (links to the full model will follow)
and the specifics:
I first drive a zero-mass segment's orientation to fit my rotational vector
data (SegOrient.any):
===== CODE START =====
AnyFunInterpol Data = {
Type = PiecewiseLinear;
FileName = .DataFile;
}; // Data
AnySeg Seg = {
Mass = 0;
Jii = {0,0,0};
AnyRefNode ISBNode = {
sRel = {0,0,0};
ARel = Main.Model.Environment.GlobalRef.ISBFrame.ARel;
AnyDrawRefFrame DrawRef = {
RGB = {0,1,0};
ScaleXYZ = {0.05,0.05,0.05} * ...ShowOrient;
}; // ISBNode
}; // Seg
AnyKinEqSimpleDriver LinDriver = {
AnyKinLinear LinMeasure = {
AnyRefFrame &Global = Main.Model.Environment.GlobalRef.ISBFrame;
AnyRefFrame &Seg = ..Seg.ISBNode;
Ref = 0;
}; // LinMeasure
Reaction.Type = {On, On, On}; // Markers need to be carried
DriverPos = {0,0,0};
DriverVel = {0,0,0};
}; // LinDriver
AnyKinEqInterPolDriver RotDriver = {
AnyKinRotational RotMeasure = {
AnyRefFrame &Global = Main.Model.Environment.GlobalRef.IRMFrame;
AnyRefFrame &Seg = ..Seg.IRMNode;
Type = RotVector;
Ref = 0;
}; // RotMeasure
T = .Data.T;
Data = .Data.Data;
}; // RotDriver
===== CODE END =====
I then drive (by limiting rotations) the segment orientation to match this
null-mass segment (Drivers.any):
AnyKinEqSimpleDriver RThighRotDriver = {
AnyKinRotational RotLink = {
AnyRefNode &Model =
Main.HumanModel.BodyModel.Right.Leg.Seg.Thigh.IRMN ode;
AnyRefNode &Marker =
Main.Model.Environment.SegmentOrientations.RThigh. Seg.IRMNode;
Type = RotVector;
}; // RotLink
MeasureOrganizer = {0,1,2};
}; // RThighRotDriver
Up to here, everything seems fine. But when I look at my model, I notice a
fairly big orientation difference between the line joining the joint centers
(hip joint to knee joint) compared to the equivalent line drawn from my
marker data (hip joint center virtual marker and knee joint center virtual
marker). At first, I blame my transformations/calculations previous to
entering it in Anybody, but strangely, the error seem to come from Anybody!
To test demonstrate this, I simply created a measure that measure directly
the orientation difference between the global reference frame and the thigh
segment (STS.main.any):
AnyKinRotational RThighRotV = {
AnyRefFrame &RefFrame = Main.Model.Environment.GlobalRef.IRMFrame;
AnyRefFrame &Thigh =
Type = RotVector;
Strangely enough, this last measure (RThighRotV) gives me a different result
than the one that is being driven (LinDriver.LinMeasure)! The error is
present both in the 3D view and the data.
Values at frame 0:
Main.Study.Output.Model.Environment.SegmentOrienta tions.RThigh.RotDriver.Rot
Measure.Pos
0.108464
0.058994
-1.187838
Main.Study.Output.Model.RThighRotV.Pos
0.08990936
0.06810572
-1.132129
So I assume that I am missing something fairly big or there is a bug, in
either case, I need your help as I am kinda stuck...
Other specifics:
- I use Anybody 2.x, although I tried on 3.x with the same results.
- I use the repository 6.0.
- I used repository 6.0 also for 3.x, although it gives me several
warnings about the Ref parameter which is now deprecated, but it worked
anyway.
Below is the link to download the model:
http://www.health-ingenio.com/Files/Model.zip
Note that the repository is not included and should be placed under
Repository.6, at the same level as the zip's directory.
Thank you very much for your help!
Jean-Olivier Racine, ing.jr
joracine@humancad.com
HumanCAD Development Team
NexGen Ergonomics Inc.
http://www.nexgenergo.com
(450) 621-0138
  #2
Old 03-10-2009, 03:35 PM
AnyScript Support
Guest
Posts: n/a
Default RE: [AnyScript] Wrong orientation when driving model
Hi Jean Olivier,
I run the model with version 3.0.1 and 3.0.2 (I don't have 2.x currently
installed) and Rep6.
The driver AnyKinEqSimpleDriver RthighRotDriver linking the thigh and the
NoMass segment is working correctly. I drew both IRMNode and they are
perfectly aligned in the model view. Also the rotational measures
Measure.Pos and Main.Study.Output.Model.RThighRotV.Pos are exactly similar.
You said the difference between the measures is also present in 3.x right?
Can you tell me exactly which version of AnyBody 3.x and 2.x are you using?
Also can you please draw the ref frame of the nodes like following and
verify that they are aligned?
Main.Model.Environment.SegmentOrientations.RThigh. Seg.IRMNode = {
AnyDrawRefFrame drw =
RGB = {1, 0, 0};
ScaleXYZ = 0.5*{1, 1, 1};
Main.HumanModel.BodyModel.Right.Leg.Seg.Thigh.IRMN ode = {
RGB = {0, 0, 1};
Then in addition of this possible problem in a certain version I think I
found another error. The SegmentOrientations.RThigh.Seg.IRMNode is not
aligned with the red line connecting the markers representing the hip and
knee joint centres, which should be if I understood well the model. The
thigh is correctly aligned with the dummy segment but as this last one is
not aligned with red lines then the thigh doesn't match either the red
lines.
That means the problem can be in the interpolated data used to drive the
dummy segment.
Did you process this data in some way? Are sure it is given in the right
coordinate system?
Sylvain, AnyBody Support
_____
Of Jean-Olivier Racine
Sent: 10. marts 2009 02:07
Cc: Rachid.Aissaoui@etsmtl.ca
Subject: [AnyScript] Wrong orientation when driving model
Hello guys,
and the specifics:
}; // Data
AnySeg Seg = {
Mass = 0;
Jii = {0,0,0};
sRel = {0,0,0};
RGB = {0,1,0};
}; // ISBNode
}; // Seg
Ref = 0;
}; // LinMeasure
}; // LinDriver
Type = RotVector;
Ref = 0;
}; // RotMeasure
T = .Data.T;
Data = .Data.Data;
}; // RotDriver
AnyRefNode &Model =
Type = RotVector;
}; // RotLink
Type = RotVector;
Values at frame 0:
Measure.Pos
0.108464
0.058994
-1.187838
0.08990936
0.06810572
-1.132129
Other specifics:
anyway.
http://www.health- <http://www.health-ingenio.com/Files/Model.zip>
joracine@humancad. <mailto:joracine%40humancad.com> com
http://www.nexgener <http://www.nexgenergo.com> go.com
(450) 621-0138
  #3
Old 03-13-2009, 03:39 AM
Jean-Olivier Racine
Guest
Posts: n/a
Hello Sylvain,
Thank you very much for your help and time. It seems the values we're in
fact identical, my mistake comes from a small bug that prevents from
charging variable in AnyChart when you have selected Data in the top window.
Therefore when I clicked on the RThighRotV measure to see its value, I was
still on the quaternion values, and I could only see the first three lines,
which prevented me from figuring out that it was a 4 value variable...
Sorry about that.
In fact, my problem was related to my transformation matrix
(GlobalFrame.IRMFrame.ARel) which we're wrong, giving a 180 degree rotation
to the thigh segments.
I am sorry you had to go through all this, yet, it still helped me to find
the solution, so thank you very, very much.
(450) 621-0138
Of AnyScript Support
Sent: March-10-09 10:36 AM
Subject: RE: [AnyScript] Wrong orientation when driving model
Hi Jean Olivier,
RGB = {1, 0, 0};
RGB = {0, 0, 1};
lines.
dummy segment.
coordinate system?
_____
From: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
[mailto:anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> ] On
Behalf
To: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
Cc: Rachid.Aissaoui@etsmtl.ca <mailto:Rachid.Aissaoui%40etsmtl.ca>
Hello guys,
and the specifics:
}; // Data
AnySeg Seg = {
Mass = 0;
Jii = {0,0,0};
sRel = {0,0,0};
RGB = {0,1,0};
}; // ISBNode
}; // Seg
Ref = 0;
}; // LinMeasure
}; // LinDriver
Type = RotVector;
Ref = 0;
}; // RotMeasure
T = .Data.T;
Data = .Data.Data;
}; // RotDriver
AnyRefNode &Model =
Type = RotVector;
}; // RotLink
Type = RotVector;
Values at frame 0:
Measure.Pos
0.108464
0.058994
-1.187838
0.08990936
0.06810572
-1.132129
Other specifics:
anyway.
(450) 621-0138
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 8.0.237 / Virus Database: 270.11.9/1991 - Release Date: 03/10/09
07:19:00
  #4
Old 03-13-2009, 03:06 PM
AnyScript Support
Guest
Posts: n/a
It is good to know that you fixed it and that it was not a bug in the
AnyForceMomentMeasure.
Good luck with your work.
_____
Sent: 13. marts 2009 03:40
Hello Sylvain,
Sorry about that.
(450) 621-0138
From: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com> ps.com
Behalf
Hi Jean Olivier,
RGB = {1, 0, 0};
RGB = {0, 0, 1};
lines.
dummy segment.
coordinate system?
_____
Behalf
Cc: Rachid.Aissaoui@ <mailto:Rachid.Aissaoui%40etsmtl.ca> etsmtl.ca
Hello guys,
and the specifics:
}; // Data
AnySeg Seg = {
Mass = 0;
Jii = {0,0,0};
sRel = {0,0,0};
RGB = {0,1,0};
}; // ISBNode
}; // Seg
Ref = 0;
}; // LinMeasure
}; // LinDriver
Type = RotVector;
Ref = 0;
}; // RotMeasure
T = .Data.T;
Data = .Data.Data;
}; // RotDriver
AnyRefNode &Model =
Type = RotVector;
}; // RotLink
Type = RotVector;
Values at frame 0:
Measure.Pos
0.108464
0.058994
-1.187838
0.08990936
0.06810572
-1.132129
Other specifics:
anyway.
<http://www.health-ingenio.com/Files/Model.zip> ingenio.com/Files/Model.zip>
http://www.nexgener <http://www.nexgener <http://www.nexgenergo.com> go.com>
go.com
(450) 621-0138
07:19:00
