Go Back   Forums Anyscript.org > Self-Supported Forum > Debug model
  #1
Old 08-05-2014, 02:09 PM
Nojoud Nojoud is offline
Junior Member
Default force plate problem
Hello;
I posted a question last night but for some reason it is not there when I checked now.
I am using full body gait and having some problems with the force plate type code in AuntoDetection when I try to run the model.
I keep getting this error : '(' unexpected
Model loading skipped.
Even though I used the recommended auto detection force plate code in the anyscript wiki, I still get the same error even if I changed the force plate type.
Your help is appreciated.
Nojoud
  #2
Old 08-05-2014, 03:09 PM
mkjung9980's Avatar
Senior Member
Default
Hi Nojoud,
This is the self-supported forum where you can't expect our official help.
Please upload your model here:
Then we will try to see what the problem is.
__________________
  #3
Old 08-06-2014, 07:37 PM
Junior Member
Default Model attached
Hello;
Please find attached the model I am using (Gait full body). I made the following changes in it:
1- In the Model Setup I changed some of the marker configuration (commented some of them out)
2- In Trial specific data I changed:
-Name file (deadlift) C3D file
- Gravity forces
- Rotated the mannequin to (-90,0, 90)
- Force plate vertical direction "Z"
- Added plate 4
- Eliminated Cal Matrix
After the following changes I tried to load the model and it gave me an unexpected error where the whole program crashes. The previous error that I had was in regards to the force plate type as I mentioned, but now its a new error.
Thank you!
  #4
Old 08-12-2014, 06:11 PM
mkjung9980's Avatar
Senior Member
Default
I've attached the modified version of your model.
I had to change several files to make your model working
1) In the 'ModelSetup.any' file
- Adjusted 'FrontFrameOffset' and 'LastFrameOffset' values to reduce the number of frames which will be analyzed
- Disabled 4 markers on the head
2) In the 'TrialSpecificData.any' file
- Adjusted the segment lengths (Anthropometrics folder)
- Adjusted the initial posture of the human model
3) In the 'Environment.any' file
- In your C3D file, your force type is 'TYPE2'. So you should use the corresponding force plate class template.
I hope this may help you.
__________________
  #5
Old 08-13-2014, 11:20 PM
Junior Member
Default markers
Dear Moonki;
Thank you for all your help. I just have one more inquiry, I noticed that you have changed the weights of some markers making some higher than other, is there any specific reason behind your selection?
Just for me to know because I will be working with other different moves ( ex. squat) so it would help if you could explain to me or maybe if you can refer me to some sources that would.
Your help is highly appreciated.
Kind Regards;
Nojoud
