Go Back   Forums Anyscript.org > Self-Supported Forum > Debug model
  #1
Old 03-06-2015, 11:59 PM
nandish nandish is offline
Junior Member
Default standing barbell lift exercise
Hello respected sir
I am doing project incorporating c3d files, When i load it is giving errors like " 'RASI' : Unresolved object" . SO what should i do should i install extra drivers or should i delete some markers, Some markers Names are not specified properly so please check my c3d file whether it is correct.
i have attached my c3d file too in the zip model( it is in the input file), please help me to rectify the problem and guide me has i am confused in how to model using c3d so direct me to some videos or tutorials which would help me thank you.
  #2
Old 03-10-2015, 09:48 AM
Senior Member
Default
Please go stepwise throught his instruction:
http://wiki.anyscript.org/index.php/...p_driven_Model
Your marker names are something with actor1:RASI and not only RASI, so please delete the actor1: part for all markers. Best way todo this is in MOKKA (3d Motion Kinematic and Kinetic Analyzer)
__________________
Best regards, Amir
__________________
  #3
Old 03-11-2015, 08:16 AM
Junior Member
thank you sir for replying my query
i have done what you recomended removed actor1: and used mokka to edit the markers and uploaded the new c3d file to the input folder and tried to load but still the problem persists . Please help me to rectify the problem
  #4
Old 03-11-2015, 09:18 AM
Senior Member
Default
It seems that you did not understand the principles of the MoCapModel yet. I recommend to look into the tutorial:
http://www.anybodytech.com/fileadmin...e/lesson5.html
and at the Wiki:
You need to follow all the steps in the Wiki entry to run the MoCapModel on your own data.
If you look into the C3D again, you see that the markes on the hip aren't named RASI, LASI, RPSI or LPSI but RFWT, LFWT, RBWT and LBWT.
You can change the name either in MOKKA in the C3D or in AnyBody in the marker.any file. Description how to do it in AnyBody is on the Wiki.
Note, you don't have forces in your C3D file, so you need to implement them afterwards as well.
__________________
Best regards, Amir
__________________
