  #1
Old 08-28-2017, 01:33 PM
mewael mewael is offline
Junior Member
Default Getting the muscle force in the X,Y,Z directions
Hallo there,
For a project i'm analyzing the Motion of a body. Therefore i need the Joints Forces and the Muscle Forces in X,Y,Z directions.
The Joint reactions give out the Forces Fx, Fy, Fz, which is really fine
but on the other hand I’m not able to get the Muscle forces Fmx, Fmy, Fmz.
I'm only getting the muscle force FM - I assume it is the resulting force of Fmx, Fmy, Fmz -
The Intersection point of the Joint (Knee or Femur) and the muscle could be seen as a pressure-point of the Force, which must have three directions x,y,z (a assumption, not sure )
I hope, I made my que. clear and i'll appreicate it if someone could help me with this issue.
Best Reagrds from germany
  #2
Old 08-30-2017, 12:18 PM
toerholm's Avatar
toerholm toerholm is offline
AnyBody Support
Default
Hi Mewael,
Please note that when you post for the first time in this forum your post will be approved manually by the administrator before it can be seen by others, this the only way to avoid spam.
The standard output from a muscles does not contain the force components just the net force in the line it is working on. Please also note that the moment in the insertation/origin point is always zero, there is no momentarm.
There are ways to measure the force components from the muscles, this can be done using an AnyForceMomentMeasure please see the reference manual and this wiki page https://github.com/AnyBody/support/w...rdinate-system
It is also possible to export all forces including muscle and joint forces to an xml file using the AnyMechOutputFileForceExport.
Please update your affiliation data, we need to know this to provide support.
__________________
  #3
Old 08-31-2017, 01:03 PM
Junior Member
Default Axes and Org/Ins points
Dear Søren,
thx a lot for your very helpful reply. I'm trying to get the components of the Muscle force using Axes (in the local-CS) of the Origin point of the muscle (as contact-point between the muscle and the segment).
i have two Questions:
1. the Axes gives me a 9*9 Matrix, is this the Transformation-Matrix in the x,y,z directions?
2. the muscle should have its own coordinate System (CS), shouldn't it? but which CS should the Origin Point have(from the Segment or muscle)?
I'll apperciate it, if you can help me
best regards
Wael
  #4
Old 08-31-2017, 01:51 PM
toerholm's Avatar
AnyBody Support
Default
Hi Wael,
Please update your profile so it is possible to see your affiliation, thx
__________________
  #5
Old 08-31-2017, 01:59 PM
Junior Member
Default
Hi Søren,
I've just updated my profile.
Best Regards
Wael
  #6
Old 08-31-2017, 04:25 PM
toerholm's Avatar
AnyBody Support
Default
Hi Mewal,
Axes is the rotation matrix of the reference frame, Axes is time dependent so if you have motion it will change. ARel is the relative rotation matrix wrt to parent frame, so not time dependent.
The muscles do not have their own coordinate systems they are basically strings between points and wrapping on surfaces, so you can not get Axes property of a muscle.
Please consider using the AnyForceMomentMeasure it has been designed to measure forces in any coordinate system you like.
__________________
  #7
Old 01-24-2018, 12:48 PM
Junior Member
Default Using AnyForceMomentMeasure
Hallo Søren,
i did a gait Analysis and i'm trying to measure a possible Torsion on the femur.
Is there anyway to measure the torque around the axial axis of the femur?.
I think the using of AnyForceMomentMeasure could be the solution, but i couldn't find any tutorial or help for the right using of AnyForceMomentMeasure.
Can youl please help me with this issue?
Regards
Wael
  #8
Old 01-24-2018, 02:48 PM
pgalibarov's Avatar
Senior Member
Default
Hi Wael,
Please check the following object (Main.HumanModel.BodyModel.Left.Leg.MomentMeasure) in the model tree to see how to do it using AnyForceMomentMeasure2 object (in case it is not yet defined there).
  #9
Old 01-24-2018, 04:27 PM
Junior Member
Default
Hallo Pavel,
i found this thread and i tried to follow the example.
https://github.com/AnyBody/support/b...ureExample.any
What i'm looking for is the torque around the axial axis of the femur (in his own Local-KS).
This is the code, what i wrote. I assumed that the RefFrame is the femur itself and i assumed that the Moments generated by the muscle in the femur are equal to the Moments, which are working on the femur. I'm not sure if i should use the moments, which are generated by the reaction forces of the joint ,, Hip"
AnyForceMomentMeasure2 MomentMeasureLoc =
AnyRefFrame &Ref = Main.CanineModel.Segs.Right.Femur;
AnySeg &Seg = Main.CanineModel.Segs.Right.Femur;
AnyFolder &Mus1 = Main.CanineModel.Muscles.Right.Vastus_lateralis_in termedius;
AnyFolder &Mus2 = Main.CanineModel.Muscles.Right.Vastus_medialis;
AnyFolder &Mus3 = Main.CanineModel.Muscles.Right.Adductor_magnus;
AnyFolder &Mus4 = Main.CanineModel.Muscles.Right.Gluteus_medius_caud alis;
Regards
Wael
  #10
Old 01-24-2018, 06:12 PM
pgalibarov's Avatar
Senior Member
Default
Hi Wael,
In the ref. manual:
"F OutputVar Equivalent point force vector in global coordinates. "
So the code, from the link I recommended looks like this:
Code:
AnyForceMomentMeasure2 KneeNetMomentMuscle = {
  AnyRefNode &ref = ..Seg.Thigh.KneeJoint.RotNode;
  AnySeg &seg1=..Seg.Shank;
  AnySeg &seg2=..Seg.Foot;
  #include  "LegMuscleNames.any"
      AnyVec3 Mlocal=M*ref.Axes;
      AnyVar MKneeFlexion=Mlocal[2];
Where the last section shows how to recompute it in the relevant ref. frame.
