Go Back   Forums Anyscript.org > General Forum > Announcements
Old 04-24-2017, 12:22 PM
sandamas sandamas is offline
Default Invalid settings file
Hi,
I have just installed the latest version of Anybody.
When I now run AB I get the following message:
Loading Settings Script from : 'C:\Users\pauls\AppData\Local\AnyBody Technology\AnyBody.6.1.x\Settings.anyst
ERROR(SCR.SCN1) : Cannot open file : C:\Users\pauls\AppData\Local\AnyBody Technology\AnyBody.6.1.x\Settings.anyst
Settings file invalid and will be recreated. Using default settings.
Is this likely to be a problem when I run AnyBody, or can I safely ignore this message?
On my computer the AnyBody program is located under : Local disk (c\ Program\AnyBody Technology\AnyBody6.1 and not
My PC is running Windows 7 in Swedish, could that be what is causing this?
Thanks for your help,
Paul
Old 04-25-2017, 12:22 PM
Hi Paul,
Sorry about this, it is not really a problem, and you should see this only the first time you start up AMS, it will not afffect the behaviour of AMS. The "error" means that when starting up the first time it will generate a new setting file if it did not find an old one.
For a future release we will make this message more meaningfull
Old 04-25-2017, 12:45 PM
Thanks for your help.
