I use AnyBody version 7.1.2.6044 and “Plug-in-gait_Simple” model.
I woudl like to calculate the translation between A) head of the femur and acetabulum, and between B) shank and femur.
Firstly I try do it for hip joint (A), and I changed the definition of “hip joint” use TransSphericalJoint function (instead SphericalJoint). However I coudn’t perform the Inverse dynamics.
Firstly I saw error:
ERROR(SCR.EXP0) : C:/U…s/J…a/D…p/N…)/A…o/Body/A…n/L…M/RightLegSelectedOutput.any(12) : ‘Hip_MediolateralForce’ : Error in expression. Please refer to the following error messages for details …
ERROR(SCR.EXP3) : C:/U…s/J…a/D…p/N…)/A…o/Body/A…n/L…M/RightLegSelectedOutput.any(12) : ‘Hip_MediolateralForce’ : Index [2] out of range for ‘AnyFloat[2]’
So, I bocked of code “Hip_MediolateralForce” (in SelectedOutput folder) into a comment. In this way two steps: LoadParameters and MarkerTracking in operation “RunAnalysis” were completed successfully. However “InverseDynamics” wasn’t completed and I saw comment:
Macro command : InverseDynamicView(1:1)> classoperation Main.ModelSetup.Views.InverseDynamicView"Set View"
Position analysis failed : 194 independent constraints and 196 unknowns
- attemps to continue (attempt no. 1)
- attemps to continue (attempt no. 2)
Velocity and acceleration analysis failed : 166 independent constraints and 168 unknowns
Constraint violations for study ‘Main.Studies.InverseDynamicStudy’ :
ERROR(OBJ.MCH.KIN1) : C:/U…s/J…a/D…p/N…)/A…o/T…s/A…p/AnyMoCapModel.any(59) : InverseDynamicStudy.InitialConditions : Model is kinematically indeterminate :
- Could you help me, where is the problem in my model?
- How should I change the definition of (A) hip joint and (B)knee joint to calculate the translation between head of the femur and acetabulum and between femur and shank, respectively (in x, y, z direction).
Thank you very much for your help.
Justyna
