Dear John,
Thanks for the quick response.
Actually, I did use a 4th order Butterworth filter and tried a couple
of different cut-off frequencies (ranging from 1 to 3.5 Hz given the
motion data was captured at 20 Hz).
In addition, I numerically twice-differentiated motion data to see
what kind of acceleration data I’ve got. The order of magnitude was
about 1e-2 to 1e-4, depending on a cut-off freq.
I expected that anyhow I would have a small A-P direction joint force
for the anckle since the foot mass is very small.
Regardless of a cut-off frequency, I had a small M-L direction joint
force and a large A-P direction joint force for the joint.
So far, I couldn’t think of what I did wrong.
Sunwook
wrote:
> Hi Sunwook,
> I had a quick look and can see that the input data is very jagged.
> This is a classical problem of mocap input: When you differentiate
> it, the noise increases a lot. I noticed that you use an 8th order
B-
> spline interpolation, but this is frequently not enough.
> Unless you have already tried it, my advice is to try to filter the
> input movement data, for instance with a Butterworth filter.
> Please let us all know how it goes.
> Best regards,
> John
> — In anyscript@yahoogroups.com, “ninegu_sun” <ninegu_sun@>
> wrote:
> > The file is uploaded.
> > Thanks for the help.
> > Sunwook
> > — In anyscript@yahoogroups.com, “AnyBody Support” <support@>
> > wrote:
> > > Hello Sunwook,
> > > It sounds like a really simple model that should be easy for us
> to
> > > decipher. Could you upload the model to the group, so that we
> can
> > > have a look at it?
> > > Thanks,
> > > John
> > > wrote:
> > > > Dear Anybody team,
> > > > I recently made a simple 3-segment model to use motion data
> from
> > > sway
> > > > study.
> > > > Three segments include one foot, one shank and one thigh, and
> > > > revolute joints are used to connect each segment. (and no
> muscle)
> > > > When checking constraint reaction forces , I saw 5 components.
> > > > The thing is that constraint reaction forces for the joint
are
> > > > somewhat unreasonable.
> > > > For the ankle, a compressive force (Fy), M-L force (Fz), and
a
> > > joint
> > > > torques are reasonable. However, an A-P force (Fx) is way too
> > > large
> > > > (about 100 N for the ankle although I expected a somewhat
> similar
> > > > value from the forceplate).
> > > > I don’t see why only A-P directoin forces look stranges when
> all
> > > the
> > > > other reaction forces look fine.
> > > > Pleaes, let me know what I’m missing here.
> > > > Sincerely,
> > > > Sunwook
