Angles
Hi Soren,
I have a question about the interpretation of the angles.
Does AnyBody interpret Euler angles, or the angles are projected in
the axes?
This question only affect in PelvisThorax, Glenohumeral and Hip when
there are two or three angles in the same point.
If the answer is Euler, how does it the angles order?
Best regards.
Hi Raul,
Yes, AnyBody’s rotational measure (AnyKinRotational) does interpret
the angles as Euler-like angles, at least when you use the
Type=RotAngleAxis.
The sequence of the three axes are determined by the
AnyKinRotational members called Axis1, Axis2, and Axis3
— In anyscript@yahoogroups.com, Raúl Borraz Lamiel
<raulborrazlamiel@…> wrote:
> Hi Soren,
in
> the axes?
when
> Best regards.
