Is there anyway to know the order in which Anybody changes joint angles (x,y,z) for a certain joint throughout an inverse dynamics operation.
I need to apply some transformation matrices to the final joint angles, however these matrices also depend on the order in which the (x,y,z) components have been changed.
I tried to output the joint angles in several steps, however the change was looked random.
Thanks
