In AnyJack.any (scaling file) I observed the relation between
Body_Mass and Segment masses but with the body_height this is not the
same.
What relation hat body_height with AnthroSegmentLengths? I add
ThighLength plus ShankLength plus PelvisWidth plus HeadHeight plus
TrunkHeight but the addition is not equal to body_height.
The body_height is used for calculating various parameters in the
model, but you are right it is not linked directly to the
AnthroSegmentLengths. You have to make sure “manually” that the
segments lengths adds up to the body height.
If you know a relation for the segments lengths dependent on the
body_height you can add those equations in the AnyJack.any file to
obtain this link.
— In anyscript@yahoogroups.com, Raúl Borraz Lamiel
<raulborrazlamiel@…> wrote:
> Hi Soren,
the
> same.
> Best regards.
