Applying ground reaction forces
Hi everyone,
I’m looking for a possibility to apply ground reaction forces to my
model. We are given the global vector to the position of the contact
point and also the vector of forces in the global coordinate system.
Like this:
t rx ry rz
0.0000000 -0.001578 0.0019055 -0.0041077
0.0025350 -0.001578 0.0019055 -0.0040675
0.0050700 -0.001578 0.0019055 -0.0040272
0.0076050 -0.001578 0.0019055 -0.0039869
and this:
t ForceX ForceY ForceZ
0.0000000 0 0 0
0.0025350 -0.0022952 0.052367 0.0026903
0.0050700 -0.0057498 0.10911 0.0054355
0.0076050 -0.010264 0.17094 0.0083138
0.0101400 -0.015739 0.23854 0.011403
How can I include this data to the “AnyForce3D” class?
AnyForce3D <ObjectName> =
//F = {0, 0, 0};
//Flocal = {0, 0, 0};
AnyRefFrame &<Insert name0> = <Insert object reference (or full
object definition)>;
Dieter
Hello Dieter,
There’s a good example of this in the Gait3D model example (repository, in
ARep/Gait3D) (in environment.any). Although not the simplest way to do it,
it is the most volatile.
If you want to keep it simple, and just include the data directly in the
AnyForce3D, you can do as in the example:
AnyForce3D ForceOnForcePlate1 ={
AnyFunInterpol force ={
 Type=Bspline;
 BsplineOrder = 8;
 FileName ="ForcePlate1.txt";
AnySeg &ref1=.CenterOfPressure1;
F=force(t);
Which create a AnyFunInterpol object, that holds all the data from you file
and “feeds” it to the AnyForce3D class, through the force(t) parameter.
CenterOfPressure1 could be replaced by a node on a segment to make things
simple. But in general, this is not the best idea: you should probably
follow the example quite closely.
Hope this helps and good luck,
Jean-Olivier
NexGen Ergonomics
Of dieterkassgim
Sent: Monday, March 10, 2008 8:35 AM
Subject: [AnyScript] Applying ground reaction forces
Hi everyone,
Like this:
t rx ry rz
and this:
0.0000000 0 0 0
//F = {0, 0, 0};
Dieter
Hi Jean-Olivier,
I am also trying to unput force plate data into my gait model,
I have 8 analog channels giving my 2x 2y and 4*z data sets.
I have started to script in the environment file based on a Florida model
that has similar analog data. I am coming unstuck where my analog data does not
have
a time or frame number column. I have tried to make a column but I
keep on getting the same error;
‘force.Data’ : The matrix must contain the same number of columns as T has
elements, i.e., the number of data and parameter values must match
I have 7826 analog figures and only 1119 frames of motion capture.
I have no forceplate.txt file, do you think i should create one or stick with
inputting the analog data?
Many thanks
peter
Jean-Olivier Racine <jean-olivier.racine.1@ens.etsmtl.ca> wrote: Hello Dieter,
 Type=Bspline;
 BsplineOrder = 8;
F=force(t);
Jean-Olivier
NexGen Ergonomics
Of dieterkassgim
Hi everyone,
Like this:
t rx ry rz
and this:
0.0000000 0 0 0
AnyForce3D =
//F = {0, 0, 0};
AnyRefFrame & =
Dieter
Users of the AnyBody Modeling System help each other create biomechanical models
in the AnyScript language.
Yahoo! Groups Links
Sent from Yahoo! Mail.
The World 's Favourite Email.
Hello Peter,
I am not sure I understand exactly your problem, but I’ll try to help you
with what I’ve got.
To my understanding:
  1.   You use the C3D import to get the force plate data, which has 7826
frames.
  1.   You use the C3D import to get the motion capture data, which has
1119 frames.
  1.   You have a AnyBodyStudy that has nStep = 1119.
So right now, you are using directly the analog data in the AnyForce3D in
something that looks like this:
AnyForce3D TheForce = {
             F = C3D.ForcePlate.Data;
If this is how you do it, then you don’t need a force plate file, what you
can do is use the AnyFunInterpol class with something like this:
             AnyFunInterpol Data = {
                             Type = Bspline;
                             BsplineOrder = 8;
                             Data = C3D.Analog.ForcePlate.Time;
                             Data = C3D.Analog.ForcePlate.Data;
F = Data(t);
Naturally, you have to replace the C3D paths with valid ones. The
ForcePlate.Time should have the same number of values has your force plate
data (7826).
This will make anybody interpolate you force plate data to match the number
of frames (and time of each frame) has your motion capture data.
Does that help you?
Jean-Olivier Racine
joracine@humancad.com
HumanCAD development team
Nexgen Ergonomics Inc.
Of Peter Worsley
Sent: Tuesday, March 11, 2008 9:47 AM
Subject: RE: [AnyScript] Applying ground reaction forces
Hi Jean-Olivier,
not have
with inputting the analog data?
Many thanks
peter
<mailto:jean-olivier.racine.1%40ens.etsmtl.ca> > wrote: Hello Dieter,
Type=Bspline;
BsplineOrder = 8;
FileName =“ForcePlate1.txt”;
F=force(t);
Jean-Olivier
NexGen Ergonomics
From: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
[mailto:anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> ] On
Behalf
Of dieterkassgim
To: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
Hi everyone,
Like this:
t rx ry rz
and this:
0.0000000 0 0 0
AnyForce3D =
//F = {0, 0, 0};
AnyRefFrame & =
Dieter
models in the AnyScript language.
Yahoo! Groups Links
Hi Jean-Olivier,
thanks for the answer. I’ve tried to work through the gait3d
Environment.any file but like you already said it’s very difficult
for a beginner like me to follow the example.
That’s why I prefer the Node solution:
 AnyForce3D GRF1 ={
     Type=Bspline;
     BsplineOrder = 8;
     FileName ="GRF_M2.txt";};
   AnyRefNode &ref1=Main.rat_model.Seg.metatarsus.GRF_M;
   // F fuer globale angreifende Kraft
   // FLocal fuer lokale angreifende Kraft
   F=force(t);
The only problem that I have now is that I would like to have the
RefNode moved during the timesteps in the local coordinate system. I
tried to implement a driver but that way my perfectly constraint
model became overconstrained. Is there a way to move a RefNode of a
segment in the local coordinate system by timesteps?
Regards
Dieter
— In anyscript@yahoogroups.com, Jean-Olivier Racine <joracine@…>
wrote:
> Hello Peter,
help you
> with what I’ve got.
has 7826
> frames.
> 2. You use the C3D import to get the motion capture data,
which has
> 1119 frames.
> 3. You have a AnyBodyStudy that has nStep = 1119.
AnyForce3D in
what you
> Type = Bspline;
> BsplineOrder = 8;
> F = Data(t);
force plate
> data (7826).
the number
> Does that help you?
> Jean-Olivier Racine
> joracine@…
On Behalf
> Of Peter Worsley
> Hi Jean-Olivier,
model
data does
> not have
as T has
stick
> Many thanks
> peter
> Jean-Olivier Racine <jean-olivier.racine.1@…
Dieter,
(repository, in
do it,
in the
> Type=Bspline;
> BsplineOrder = 8;
> F=force(t);
you file
parameter.
things
probably
> Jean-Olivier
> NexGen Ergonomics
> Behalf
> Of dieterkassgim
> Hi everyone,
contact
> Like this:
> t rx ry rz
> and this:
> 0.0000000 0 0 0
> AnyForce3D =
> //F = {0, 0, 0};
> AnyRefFrame & =
> Kind regards,
> Dieter
biomechanical
> Yahoo! Groups Links
Hello Dieter,
The answer to your question is yes and no:
Yes:
Using a driver, like you tried, you can move a node and it is a perfectly
valid operation, on its own.
No:
Unless your model was planned to be driven by one of its node, adding
unplanned drivers will certainly make your model over constrained. In the
Gait3D webcast, there’s a fairly good example of how to calculate the
degrees of freedom (DOF) a model has. You cannot create more drivers (a
driver, in this case, meaning a constraint to one of the
translation/rotation) than there are DOFs.
That is why the Gait3D example uses another way to input ground reaction
forces. Physiologically, we cannot say that the ground reaction force is in
fact AT the location of the anatomical node. In reality, your COP is moving
around the given node. A good example of this is just before heel strike,
during gait: because the forces are really small, the errors on the COP
calculations are enormous, which makes the COP move several meters around
the model, really far from the true heel strike location, before stabilizing
under the foot AT heel-strike.
So what the Gait3D example does is use the “yes” and “no” answers from
above:
  1.   It creates an zero-mass segment (CenterOfPressure1) onto which it
declares a node at its center (node).
a. Because a new segment is created, we added a new 6 DOF to the
model.
  1.   It creates two measures that measures the position and the
orientation of the segment in the global reference system (Lin1, Rot1).
  1.   It then drives the position of this zero-mass segment using the COP
position data (LinDrv1).
a. Because this segment is not attached to anything, it can move
anywhere freely without having impacts on your model kinematics constraints.
b. Because we are only interested at the position of the COP/zero-mass
segment, we just set the orientation to be the same as the global reference
system (RotDrv1).
  1.   It then creates an AnyForce3D (ForceOnForcePlate1) which takes the
force plate data and applies it on the zero-mass segment. In other words,
the force is applied to a free moving zero-mass segment, not directly to
your model.
  1.   Finally, it creates an AnyReactForce (ForcePlate1FootRContactForce)
which will link, in terms of force equilibrium equations, the COP node
(zero-mass segment) and the node on the model (in the example, the foot).
This means you have two choices for inputting your ground reaction force to
your model:
  1.   Either you assume the COP is AT the anatomical node and therefore
do not use the COP data and just create an AnyForce3D that is applied to the
anatomical node (which is what you did right now).
  1.   Either you use the Gait3D example approach (previous steps 1 to 5)
to be able to have a COP that moves independently of your model.
I hope this will help you understand how to do what you want,
Jean-Olivier Racine
Of dieterkassgim
Sent: Wednesday, March 12, 2008 9:17 AM
Subject: [AnyScript] Re: Applying ground reaction forces
Hi Jean-Olivier,
AnyForce3D GRF1 ={
Type=Bspline;
BsplineOrder = 8;
FileName =“GRF_M2.txt”;};
F=force(t);
Regards
Dieter
— In anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> ,
wrote:
> Hello Peter,
help you
> with what I’ve got.
has 7826
> frames.
which has
> 1119 frames.
AnyForce3D in
what you
> Type = Bspline;
> BsplineOrder = 8;
> F = Data(t);
force plate
> data (7826).
the number
> Does that help you?
> Jean-Olivier Racine
> joracine@…
On Behalf
> Of Peter Worsley
> Hi Jean-Olivier,
model
data does
> not have
as T has
stick
> Many thanks
> peter
Dieter,
(repository, in
do it,
in the
> Type=Bspline;
> BsplineOrder = 8;
> F=force(t);
you file
parameter.
things
probably
> Jean-Olivier
> NexGen Ergonomics
<mailto:anyscript%
> Behalf
> Of dieterkassgim
> Hi everyone,
contact
> Like this:
> t rx ry rz
> and this:
> 0.0000000 0 0 0
> AnyForce3D =
> //F = {0, 0, 0};
> AnyRefFrame & =
> Kind regards,
> Dieter
biomechanical
> Yahoo! Groups Links
Hi Jean-Olivier,
thank you for your informations. I will try to implement your
suggestions (steps 1 to 5).
Dieter
wrote:
> Hello Dieter,
> Yes:
perfectly
> No:
adding
In the
the
drivers (a
reaction
force is in
is moving
strike,
COP
around
stabilizing
from
> above:
which it
the
> model.
> 2. It creates two measures that measures the position and the
Rot1).
> 3. It then drives the position of this zero-mass segment
using the COP
move
constraints.
COP/zero-mass
reference
> system (RotDrv1).
> 4. It then creates an AnyForce3D (ForceOnForcePlate1) which
takes the
words,
directly to
> your model.
> 5. Finally, it creates an AnyReactForce
node
foot).
force to
> your model:
therefore
applied to the
> 2. Either you use the Gait3D example approach (previous steps
1 to 5)
> Jean-Olivier Racine
> joracine@…
On Behalf
> Of dieterkassgim
> Hi Jean-Olivier,
> AnyForce3D GRF1 ={
> Type=Bspline;
> BsplineOrder = 8;
> F=force(t);
I
> Regards
> Dieter
> Jean-Olivier Racine <joracine@>
> wrote:
> > Hello Peter,
> help you
> > with what I’ve got.
> has 7826
> > frames.
> which has
> > 1119 frames.
> AnyForce3D in
> what you
> > Type = Bspline;
> > BsplineOrder = 8;
> > F = Data(t);
> force plate
> > data (7826).
> the number
> > Does that help you?
> > Jean-Olivier Racine
> > joracine@
40yahoogroups.com>
> On Behalf
> > Of Peter Worsley
40yahoogroups.com>
> > Hi Jean-Olivier,
Florida
> model
> data does
> > not have
> as T has
capture.
or
> stick
> > Many thanks
> > peter
> Dieter,
> (repository, in
to
> do it,
> in the
> > Type=Bspline;
> > BsplineOrder = 8;
> > F=force(t);
from
> you file
> parameter.
make
> things
> probably
> > Jean-Olivier
> > NexGen Ergonomics
40yahoogroups.com>
40yahoogroups.com>
> <mailto:anyscript%
> > Behalf
> > Of dieterkassgim
> > Hi everyone,
my
> contact
system.
> > Like this:
> > t rx ry rz
> > and this:
> > 0.0000000 0 0 0
> > AnyForce3D =
> > //F = {0, 0, 0};
> > AnyRefFrame & =
> > Kind regards,
> > Dieter
> biomechanical
> > Yahoo! Groups Links
Hi Jean-Olivier,
I now have set up the files you suggested and the interpolation is working. Many
thanks for your advice
best wishes
Peter
Jean-Olivier Racine <joracine@humancad.com> wrote: Hello Peter,
with what I’ve got.
frames.
1119 frames.
                             Type = Bspline;
                             BsplineOrder = 8;
F = Data(t);
data (7826).
Does that help you?
Jean-Olivier Racine
Of Peter Worsley
Hi Jean-Olivier,
not have
Many thanks
peter
Jean-Olivier Racine
Type=Bspline;
BsplineOrder = 8;
F=force(t);
Jean-Olivier
NexGen Ergonomics
[mailto:anyscript@yahoogroups.com ] On
Behalf
Of dieterkassgim
Hi everyone,
Like this:
t rx ry rz
and this:
0.0000000 0 0 0
AnyForce3D =
//F = {0, 0, 0};
AnyRefFrame & =
Dieter
Yahoo! Groups Links
Yahoo! Groups Links
I’m still having trouble to implement the GRFs. This is what I did
(analog to the 3D-Gait model):
(1) Definig an additional segment:
AnySeg GroundSegmentM = {
r0 = {0, 0, 0};
Axes0 = {{1, 0, 0}, {0, 1, 0}, {0, 0, 1}};
Mass = 0;
Jii={0.0,0.0,0.0};
AnyRefNode GRF_M = {sRel = {0, 0, 0};
(2) Implementing kinematic measures:
 AnyKinLinear PLin = {
   //Ref = -1;
   AnyFixedRefFrame  &ref1= Main.rat_model.ground;
   AnyRefFrame &LabOrigin = Main.rat_model.Seg.GroundSegmentM;
 AnyKinEq RotDrvM={
   AnyKinRotational rot={
     Type=RotAxesAngles;    };
(3) Driving the measure
 AnyKinEqInterPolDriver Driver =  {
   Type = PiecewiseLinear ;
   FileName = "GroundDriver_trans.txt";
   AnyKinMeasure &ref = .PLin;
(4) Using the code from the Gait3D model
 AnyReacForce GroundFootContactForceM = {
   AnyKinLinear Lin={
     //very very important this ensure that the reaction is
between artifical segment and the foot
//and not between foot and globalref if Ref had been equal -1
which is default
Ref=0;
AnySeg &ref1 = Main.rat_model.Seg.GroundSegmentM;
AnyRefNode &ref2 =Main.rat_model.Seg.metatarsus;
(5) Applying the forces
 AnyForce3D GRF1 ={
   AnyFunInterpol force = {
     Type = PiecewiseLinear;
     FileName ="GRF_M.txt";
   F=force(t);
Now I get the warning:
Model Warning: Study ‘Main.MyStudy’ contains more reaction forces
than rigid-body degrees of freedom of the segments. The model may be
statically indeterminate. There are 49 reactions and only 48 rigid
body degrees of freedom.
Here are some model informations:
Total number of rigid-body d.o.f.: 48
Total number of constraints:
Joints: 25
Drivers: 17
Other: 6
Total: 48
Total number of active reaction and driver forces: 49
I can’t understand where the problem is. Can anybody help?
Regards
Dieter
— In anyscript@yahoogroups.com, “dieterkassgim” <dieterkassgim@…>
wrote:
> Hi Jean-Olivier,
> AnyForce3D GRF1 ={
> Type=Bspline;
> BsplineOrder = 8;
> F=force(t);
I
> Regards
> Dieter
> — In anyscript@yahoogroups.com, Jean-Olivier Racine <joracine@>
> wrote:
> > Hello Peter,
> help you
> > with what I’ve got.
which
> has 7826
> > frames.
> which has
> > 1119 frames.
> AnyForce3D in
> what you
> > Type = Bspline;
> > BsplineOrder = 8;
> > F = Data(t);
> force plate
> > data (7826).
> the number
> > Does that help you?
> > Jean-Olivier Racine
> > joracine@
> On Behalf
> > Of Peter Worsley
> > Hi Jean-Olivier,
Florida
> model
> data does
> > not have
> as T has
capture.
or
> stick
> > Many thanks
> > peter
> Dieter,
> (repository, in
to
> do it,
> in the
> > Type=Bspline;
> > BsplineOrder = 8;
> > F=force(t);
from
> you file
> parameter.
make
> things
> probably
> > Jean-Olivier
> > NexGen Ergonomics
> > Behalf
> > Of dieterkassgim
> > Hi everyone,
my
> contact
system.
> > Like this:
> > t rx ry rz
> > and this:
> > 0.0000000 0 0 0
> > AnyForce3D =
> > //F = {0, 0, 0};
> > AnyRefFrame & =
> > Kind regards,
> > Dieter
> biomechanical
> > Yahoo! Groups Links
Hello Dieter,
Your problem is in step (3), you only drove the segment with a linear
driver. You have to drive its orientation too. Because we don’t care about
its orientation, you can just ensure that it is always aligned with the
global reference frame. In the Gait3D example, that driver is called
RotDrv1. If you add this driver, everything should work fine.
Have a good day!
Jean-Olivier Racine
http://www.nexgenergo.com/
Of dieterkassgim
Sent: Monday, March 17, 2008 9:28 AM
r0 = {0, 0, 0};
Mass = 0;
Jii={0.0,0.0,0.0};
//Ref = -1;
AnyKinEq RotDrvM={
FileName = “GroundDriver_trans.txt”;
AnyKinLinear Lin={
which is default
Ref=0;
AnyForce3D GRF1 ={
FileName =“GRF_M.txt”;
F=force(t);
Joints: 25
Drivers: 17
Other: 6
Total: 48
Regards
Dieter
wrote:
> Hi Jean-Olivier,
> AnyForce3D GRF1 ={
> Type=Bspline;
> BsplineOrder = 8;
> F=force(t);
I
> Regards
> Dieter
> wrote:
> > Hello Peter,
> help you
> > with what I’ve got.
which
> has 7826
> > frames.
> which has
> > 1119 frames.
> AnyForce3D in
> what you
> > Type = Bspline;
> > BsplineOrder = 8;
> > F = Data(t);
> force plate
> > data (7826).
> the number
> > Does that help you?
> > Jean-Olivier Racine
> > joracine@
> On Behalf
> > Of Peter Worsley
> > Hi Jean-Olivier,
Florida
> model
> data does
> > not have
> as T has
capture.
or
> stick
> > Many thanks
> > peter
> Dieter,
> (repository, in
to
> do it,
> in the
> > Type=Bspline;
> > BsplineOrder = 8;
> > F=force(t);
from
> you file
> parameter.
make
> things
> probably
> > Jean-Olivier
> > NexGen Ergonomics
<mailto:anyscript%
> > Behalf
> > Of dieterkassgim
> > Hi everyone,
my
> contact
system.
> > Like this:
> > t rx ry rz
> > and this:
> > 0.0000000 0 0 0
> > AnyForce3D =
> > //F = {0, 0, 0};
> > AnyRefFrame & =
> > Kind regards,
> > Dieter
> biomechanical
> > Yahoo! Groups Links
Thanks a lot, Jean-Olivier! It works fine now!
Have a good day too!
Dieter
wrote:
> Hello Dieter,
linear
care about
the
> Have a good day!
> Jean-Olivier Racine
> joracine@…
On Behalf
> Of dieterkassgim
> Hello,
> r0 = {0, 0, 0};
> Mass = 0;
> Jii={0.0,0.0,0.0};
> //Ref = -1;
> AnyKinEq RotDrvM={
> AnyKinLinear Lin={
> which is default
> Ref=0;
> AnyForce3D GRF1 ={
> F=force(t);
be
> Joints: 25
> Drivers: 17
> Other: 6
> Total: 48
> Regards
> Dieter
> “dieterkassgim” <dieterkassgim@>
> wrote:
> > Hi Jean-Olivier,
difficult
> > AnyForce3D GRF1 ={
> > Type=Bspline;
> > BsplineOrder = 8;
> > F=force(t);
system.
> I
a
> > Regards
> > Dieter
> > wrote:
> > > Hello Peter,
to
> > help you
> > > with what I’ve got.
> which
> > has 7826
> > > frames.
> > which has
> > > 1119 frames.
> > AnyForce3D in
file,
> > what you
> > > Type = Bspline;
> > > BsplineOrder = 8;
> > > F = Data(t);
The
> > force plate
> > > data (7826).
match
> > the number
> > > Does that help you?
> > > Jean-Olivier Racine
> > > joracine@
> > On Behalf
> > > Of Peter Worsley
> > > Hi Jean-Olivier,
> Florida
> > model
analog
> > data does
> > > not have
but I
columns
> > as T has
match
> capture.
> or
> > stick
> > > Many thanks
> > > peter
> > Dieter,
> > (repository, in
way
> to
> > do it,
directly
> > in the
> > > Type=Bspline;
> > > BsplineOrder = 8;
> > > F=force(t);
> from
> > you file
> > parameter.
> make
> > things
> > probably
> > > Jean-Olivier
> > > NexGen Ergonomics
> <mailto:anyscript%
> > > Behalf
> > > Of dieterkassgim
> > > Hi everyone,
to
> my
> > contact
> system.
> > > Like this:
> > > t rx ry rz
> > > and this:
> > > 0.0000000 0 0 0
> > > AnyForce3D =
> > > //F = {0, 0, 0};
> > > AnyRefFrame & =
> > > Kind regards,
> > > Dieter
> > biomechanical
> > > Yahoo! Groups Links
