Array index
Is it possible to address an entry in an array with a variable index?
I have unsuccessfully tried using the [] operator eg:
AnyInt t=round(.Study.t);
AnyVar=Data[t];
Thanks
James
Hi James
I believe that is possible if the .Study.t is available when you use
it and Data is an array it shouldn’t be a problem. I think you are
doing it the right way, maybe if you haven’t solved it you could
upload it?
Christian, AnyBody Support
> AnyVar=Data[t];
> Thanks
> James
Hi James
(and Christian),
I think that Christian might have misunderstood you (or maybe I have;-
). Anyway, here is my answer.
The indexing operator, i.e. [], does currently allow constant
integers only (as you have experienced). There is no really good
reason for this, except history. This limitation was obvious in the
early versions of AnyBody before it had integer variables at all. And
now the indexing operator has simply not followed along with other
new features of AnyScript. But it is coming…
It is already implemented in the prototypes of version 3.0, and now
that we have seen the public demand for the functionality, we
consider whether we can easily transfer this to version 2.1 that it
still waiting to be released.
Well I hope this answer the strange behavior, but it does not solve
your problem…
I wonder if we can figure out to make a work-around.
What if you make an interpolation function using Data[] as the data
for the interpolation. If you use piecewise linear interpolation,
your function will pass through the data points. I think this implies
that you can do what you want to do by
AnyInt t = round(.Study.t);
AnyVar var = f_Data(t);
where f_Data is the interpolation function.
I hope this bring you a bit forward.
Michael, AnyBody Support
wrote:
> Hi James
> upload it?
> Best regards
> — In anyscript@yahoogroups.com, “jamesshippen” <jamesshippen@>
index?
> > AnyVar=Data[t];
> > Thanks
> > James
Hi Michael and Christian
Many thanks to you both; I must admit my original question was more
directed more towards the use of variable array indices than
availability of .Study.t but all information greatfully received.
I tried the suggestion of using AnyFunInterpol as below:
AnyFunInterpol right_heel = {
Data = {Main.Model.Mannequin.Posture.Right.HEE};
T = Main.Model.Mannequin.Posture.Time;
Type=PiecewiseLinear;
AnyInt t = round(Main.Study.t);
AnyVar var=right_heel(t);
But received the error:
ERROR(SCR.EXP8) : C:\FreePostureMove\Environment.any
(41) : ‘right_heel’ : Illegal function argument
list ‘right_heel’(‘AnyInt’).
Supported function use :
Have I umplemented the function correctly?
Ta!
James
PS As a typical user, I would certainly welcome the use of non-
contact array indices ASAP!
wrote:
> Hi James
> (and Christian),
have;-
And
> your problem…
implies
> Best regards,
> wrote:
> > Hi James
use
> > upload it?
> > Best regards
> index?
> > > AnyVar=Data[t];
> > > Thanks
> > > James
Hi James,
One more small deficiency related to integers, it seems; this time
for the AnyInterpolFunction - sorry.
Try making ‘t’ a floating point variable, i.e.
AnyVar t = round(Main.Study.t);
This should be ok since it can still hold the integer value of course.
An AnyVar shoule be acceptable input for the function.
> Ta!
> James
> wrote:
> > Hi James
> > (and Christian),
> have;-
the
> And
other
now
it
solve
> > your problem…
data
> implies
> > Best regards,
> > wrote:
> > > Hi James
you
> use
are
> > > upload it?
> > > Best regards
<jamesshippen@>
variable
> > index?
> > > > AnyVar=Data[t];
> > > > Thanks
> > > > James
Hi Michael
Ta…but!
I tried:
T = Main.Model.Mannequin.Posture.PelvisPosTime;
but it return the error:
ERROR(SCR.EXP1) : C:\research\Repository.6
\Repository.6w\ARep\Aalborg\FreePostureMove\Environment.any
(41) : ‘=’ : Illegal operation for given argument
types : ‘AnyFloat’ ‘=’ ‘AnyFloat[1]’
Sorry to be a pain!!1
James
wrote:
> Hi James,
course.
> Best regards,
more
> > Ta!
> > James
> > wrote:
> > > Hi James
> > > (and Christian),
> > have;-
good
> the
all.
> > And
> other
> now
that
> it
> solve
> > > your problem…
> data
interpolation,
> > implies
> > > Best regards,
> > > wrote:
> > > > Hi James
> you
> > use
you
> are
could
> > > > upload it?
> > > > Best regards
> <jamesshippen@>
> variable
> > > index?
> > > > > AnyVar=Data[t];
> > > > > Thanks
> > > > > James
Hi James,
Try
AnyFloat var=right_heel(t);
or
AnyVector var=right_heel(t);
AnyScript is a bit sensitive to assignment of scalars (AnyVar) with
vectors/matrices on the right-hand side. This is in general ok, but
it can, as in your case, be a bit confusing when the vector/matrix
has only one element.
The interpolation function is always returning vector quantities,
also when it is only one data set you interpolate. It is designed to
interpolate vector quantities.
wrote:
> Hi Michael
> Ta…but!
> I tried:
> James
> wrote:
> > Hi James,
time
> course.
> > Best regards,
> more
received.
> > > Ta!
> > > James
> > > wrote:
> > > > Hi James
> > > > (and Christian),
I
> > > have;-
> good
in
> > the
> all.
> > > And
> > other
and
> > now
> that
> > it
> > solve
> > > > your problem…
the
> > data
> interpolation,
> > > implies
> > > > Best regards,
<support@>
> > > > wrote:
> > > > > Hi James
when
> > you
> > > use
> you
> > are
> could
> > > > > upload it?
> > > > > Best regards
> > <jamesshippen@>
> > variable
> > > > index?
> > > > > > AnyVar=Data[t];
> > > > > > Thanks
> > > > > > James
Success (with both AnyFloat and AnyVector)!!
Many thanks
James
wrote:
> Hi James,
> Try
> or
to
> Best regards,
> wrote:
> > Hi Michael
> > Ta…but!
> > I tried:
> > James
> > wrote:
> > > Hi James,
> time
> > course.
> > > Best regards,
<jamesshippen@>
was
> > more
> received.
> > > > Ta!
> > > > James
non-
<support@>
> > > > wrote:
> > > > > Hi James
> > > > > (and Christian),
maybe
> I
> > > > have;-
constant
> > good
obvious
> in
> > > the
at
> > all.
> > > > And
with
> > > other
> and
> > > now
we
> > that
> > > it
not
> > > solve
> > > > > your problem…
> the
> > > data
> > interpolation,
this
> > > > implies
> > > > > Best regards,
> <support@>
> > > > > wrote:
> > > > > > Hi James
> when
> > > you
> > > > use
think
> > you
> > > are
you
> > could
> > > > > > upload it?
> > > > > > Best regards
> > > <jamesshippen@>
> > > variable
> > > > > index?
> > > > > > > AnyVar=Data[t];
> > > > > > > Thanks
> > > > > > > James
