Hi Soeren,
now the model loads when I use the Muscles.any file and excluded the others. But
the new problem is, that the inverse dynamic analysis doesn`t run anymore…
The task of the model is to hold his hand in the position it has from the
beginning. So I took the Gearstick-Model and set the way the gearstick has to be
moved to zero. Then I removed the driver who gave support to the hand in
y-direction. In the old version before it doesn´t load anymore, the kinematik
analysis could be solved. Should I upload it again?
Best regards, Maren
----- Ursprüngliche Mail ----
Von: AnyBody Support <support@anybodytech.com>
An: anyscript@yahoogroups.com
Gesendet: Montag, den 31. Juli 2006, 12:31:55 Uhr
Betreff: [anyscript] Re: unresolved objects
Hi Maren
The file Muscles.any should be used, not the other one, i did not
see this problem, with my version. I think this should be corrected
in the file Arm3d/ShoulderArm. root.any
I think i was a bit too fast when i uploaded the file previously so
i have now updated it slightly again, though this is not related to
the issue you mention. Please try out the new version. The problem
was that the new file still used the simple muscle model.
After these corrections i hope you will be able to control the
muscle model from the main file.
Soeren, AnyBody Support
— In anyscript@yahoogrou ps.com, “Maren” <anystarter@ …> wrote:
> Hi Christian,
> with the new
> Brep/Aalborg/ BodyModels/ spinetwoarms/ bodymodel_ mus3e.any
> there are two include files where some muscles get defined
doubled.
> It´s
> #include “Muscle.any”
> #include “Muscles-forearm. any”
> which leads to the error message
> ERROR(SCR.PRS1) :
P:\personal\ p_maren\Anastra\ aktuell\Nachbau\ BRep\Aalborg\ Arm3D\Muscle
s-forearm.any( 8)
> : ‘Triceps_LH_ 1’ : Object already declared at :
.any(1179)
> : ‘Triceps_LH_ 1’
> Should I outcomment one of them and if yes, which one?
> Normally I switch in the main file from muscles to no muscles, but
> after working on the model in the in doesn´t load anymore and I´m
not
> shure, what I´ve done. This was because it still runs in the
> afternoon, but the next morning it wasn´t running anymore. The only
> possibility to make it run again was to change the include files
like
> I wrote in the first male.
> To leave the BRep like it is, what should I do now to make it run?
> With best regards, Maren
> — In anyscript@yahoogrou ps.com, “AnyBody Support” <support@>
wrote:
> > Hi Maren
> > In principle it should not be needed to make changes in the BRep
to
> > shift the muscle model of an arm. This can be controlled from
main
> > file of the application, this is the right way to do this. You
can
> > also do it like you where trying to do but it is more
complicated.
> > The model structure is build with the intention that the Brep
should
> > in general be left “untouched” by the various application which
is
> > using it.
> > If you include the line
#include “…\BRep\ Aalborg\BodyMode ls\SpineTwoArms\ BodyModel. an
> > y” from your main file
> > you will automatically use a model with the three element hill
model
> > for the arm muscles, please remember it will need calibration.
> > unfortunately there was a bug in the file
> > I have uploaded a new one to the file section of the group.
> > Best regards
> > — In anyscript@yahoogrou ps.com, “Maren” <anystarter@ > wrote:
> > > Hello Christian, I uploaded the model and the interesting part
of
> > the
> > > BRep in the “unresolved_ object” folder. If you change (lines
115-
> > 117,
> > > ShoulderArm. root.any)
> > > //This the parameters if a simple muscle model are being
used,
> > > contains only F0
> > > #include “Muscle-parameters- shoulder- simple.any”
> > > // #include “Muscle-parameters- shoulder- const.any”
> > > to
used,
> > > contains only F0
> > > // #include “Muscle-parameters- shoulder- simple.any”
> > > the model will not load. What should I do to use the more
accurate
> > > muscle model?
> > > Best regards, Maren
> > > — In anyscript@yahoogrou ps.com, “Christian Gammelgaard”
<cgol03@>
> > > wrote:
> > > > Hi Maren
> > > > Could you upload the model and we can have a look?
> > > > Regards Christian
wrote:
> > > > > Hello again,
> > > > > I get the failure message when I try to load a file. But
the
> > > > > unresolved object is completely defined and the path is
ok.
> > What could
> > > > > be the problem? I know that I have to look if all “;” are
> > where they
> > > > > should be and if all brackets are closed. Which files
could
> > influence
> > > > > this error, are this all files which are included till the
> > position
> > > > > which is denoted behind the failure message? Where will I
have
> > to look
> > > > > and what kind of mistake could create such an error
message?
