Center of Mass for forearm
one problem is solved and now I´ve got a new one: When I look at the
forearm, the center of mass seems to be outside the segment. When I
include a reference frame at the coordinates of “sCOM” of the ulna, it
appears in the elbow joint and not in the middle (more or less) of the
forearm, even if I ran the kinematic analysis. Have I overlooked a
reference? I think it`s a problem if there are inertias but the CoM is
not at his natural place. Is there another place to define “sCOM” of a
segment, or are there references?
With best regards, Maren
Hi Maren
Which model is it you are working with? or could you zip it and upload it?
Regards Christian
Maren wrote:
> Hello,
Hi Christian,
I included the AnyDrawRefFrames on a wrog position in the file. They
showed the reference frame of the segment and not the Center of mass.
Now I´ve found the right place for AnyDrawRefFrame and they show a
realistic position for the CoM. So there is no problem any longer,
thank yuo very much, with best regards, Maren
— In anyscript@yahoogroups.com, Christian Gammelgaard <cgol03@…>
wrote:
> Hi Maren
upload it?
> Regards Christian
> Maren wrote:
> > Hello,
Hi Maren
ok:D
Regards Christian
Maren wrote:
> Hi Christian,
> — In anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>,
> wrote:
> > Hi Maren
> upload it?
> > Regards Christian
> > Maren wrote:
> > > Hello,
Hello again, it`s my fault, I included the AnyDrawRefFrame on the
wrong place. I found the Center of Mass where it should be. Here I
don´t need help anymore. With best regards, Maren
