I would like to model the contact forces at the interface between the exoskeleton and the human. I have tried using the conditional contact class (the same from Ground Reaction Force prediction and the Seated Human example) and I got fairly good results so far. It turned out that the frictional forces evaluated by this class played an important role in my results.
However, the contact surface defined in this class is a plane surface with a well defined normal direction. I would like to refine my model further to simulate the curved surface contact between the exoskeleton and the human skin. For my exoskeleton, I created a simple model in SolidWorks and used the SolidWorks to AnyBody plugin. So, I have the STL file of the surface of the exoskeleton that should contact with the skin. On the other hand, for the skin, I am defining a few nodes on the patch that should contact with the exoskeleton.
Any suggestions on how should I proceed to define a curved surface contact in the Conditional Contact class?
